I am attempting to update the frontend polymer code with a newly built homeassistant frontend build. I have gone through the steps here https://home-assistant.io/developers/frontend/ to create a tar.gz file that should be able to update the base hass_frontend package.
When I do that and browse to home assistant I get the following in the logs:
File "/usr/local/lib/python3.6/site-packages/aiohttp/web_protocol.py", line 422, in start
yield from resp.prepare(request)
File "/usr/local/lib/python3.6/site-packages/aiohttp/web_fileresponse.py", line 177, in prepare
st = filepath.stat()
File "/usr/local/lib/python3.6/pathlib.py", line 1136, in stat
return self._accessor.stat(self)
File "/usr/local/lib/python3.6/pathlib.py", line 387, in wrapped
return strfunc(str(pathobj), *args)
FileNotFoundError: [Errno 2] No such file or directory: '/usr/src/connected-homes/build/service_worker.js'
Yes that is not a correct directory, as the docker container doesn’t include that in it and apparently neither does the install of the new python package.
Any help would be appreciated.
Craig
