An issue has recently appeared on our systems which are based on HassOS. This issue manifests, we assume, because of sudden power loss.
It manifests so: after the system loses power, it is started again, and during the startup process, docker fails to start. After failing to startup, the system automatically reboots itself, and so starts an endless loop of startups. Startup -> Docker fails -> reboot -> cycle repeats.
Of the messages shown during startup, the following seem to be the most relevant:
Starting HassOS Configuration Manager...
Starting Network Manager Wait Online...
[ OK ] Started Network Manager Script Dispatcher Service.
[ 10.349615] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.453699] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 10.461157] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.485051] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 10.573825] smsc95xx 1-1.5.1:1.0 eth1: hardware isn't capable of remote wakeup
[ 10.581438] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ OK ] Started Network Manager Wait Online.
[ OK ] Reached target Network is Online.
Starting Docker Application Container Engine...
Starting Avahi mDNS/DNS-SD Stack...
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[FAILED] Failed to start Docker Application Container Engine.
See 'systemctl status docker.service' for details.
[DEPEND] Dependency failed for Getty on tty1.
[DEPEND] Dependency failed for Docker SWARM Watchdog.
[DEPEND] Dependency failed for Dropbear SSH daemon.
[DEPEND] Dependency failed for COMPANY Bootstrap.
[DEPEND] Dependency failed for Serial Getty on ttyAMA0.
[ OK ] Started HassOS Configuration Manager.
[ OK ] Reached target Login Prompts.
[ OK ] Reached target Multi-User System.
Starting Update UTMP about System Runlevel Changes...
[ OK ] Stopped Docker Application Container Engine.
[ OK ] Closed Docker Socket for the API.
Stopping Docker Socket for the API.
Starting Docker Socket for the API.
[ OK ] Listening on Docker Socket for the API.
[ OK ] Started Update UTMP about System Runlevel Changes.
We have mounted the systems drive on a laptop, and looked at the systemd messages from docker, which are quite a lot. For the most part, the content looks like a dump of the active goroutines:
Oct 10 08:13:59 company dockerd[278]: /build/buildroot/output/host/lib/go/src/internal/poll/fd_posix.go:56 +0x70
Oct 10 08:13:59 company dockerd[278]: os.(*File).Sync(0x3d222b8, 0x16d6564, 0x4f2dc80)
Oct 10 08:13:59 company dockerd[278]: /build/buildroot/output/host/lib/go/src/os/file_posix.go:128 +0x3c
Oct 10 08:13:59 company dockerd[278]: github.com/docker/docker/pkg/ioutils.(*atomicFileWriter).Close(0x47c6940, 0x0, 0x0)
Oct 10 08:13:59 company dockerd[278]: /build/buildroot/output/build/docker-engine-v18.09.0/_gopath/src/github.com/docker/docker/pkg/ioutils/fswriters.go:68 +0x5c
Oct 10 08:13:59 company dockerd[278]: github.com/docker/docker/container.(*Container).WriteHostConfig(0x3cf9e00, 0x44cc000, 0x0, 0x0)
Oct 10 08:13:59 company dockerd[278]: /build/buildroot/output/build/docker-engine-v18.09.0/_gopath/src/github.com/docker/docker/container/container.go:255 +0x21c
Oct 10 08:13:59 company dockerd[278]: github.com/docker/docker/container.(*Container).toDisk(0x3cf9e00, 0x0, 0x0, 0x0)
Oct 10 08:13:59 company dockerd[278]: /build/buildroot/output/build/docker-engine-v18.09.0/_gopath/src/github.com/docker/docker/container/container.go:181 +0x1e8
Oct 10 08:13:59 company dockerd[278]: github.com/docker/docker/container.(*Container).CheckpointTo(0x3cf9e00, 0x18e79a8, 0x3c0ee98, 0x0, 0x0)
Oct 10 08:13:59 company dockerd[278]: /build/buildroot/output/build/docker-engine-v18.09.0/_gopath/src/github.com/docker/docker/container/container.go:192 +0x1c
Oct 10 08:13:59 company dockerd[278]: github.com/docker/docker/daemon.(*Daemon).checkpointAndSave(0x3cf4d00, 0x3cf9e00, 0x0, 0x0)
Oct 10 08:13:59 company dockerd[278]: /build/buildroot/output/build/docker-engine-v18.09.0/_gopath/src/github.com/docker/docker/daemon/daemon.go:1391 +0x84
Oct 10 08:13:59 company dockerd[278]: github.com/docker/docker/daemon.(*Daemon).restore.func1(0x4901a00, 0x3cf4d00, 0x4901a10, 0x4576c80, 0x4576c60, 0x4576c40, 0x3cf9e00)
Oct 10 08:13:59 company dockerd[278]: /build/buildroot/output/build/docker-engine-v18.09.0/_gopath/src/github.com/docker/docker/daemon/daemon.go:273 +0x6c
Oct 10 08:13:59 company dockerd[278]: created by github.com/docker/docker/daemon.(*Daemon).restore
Oct 10 08:13:59 company dockerd[278]: /build/buildroot/output/build/docker-engine-v18.09.0/_gopath/src/github.com/docker/docker/daemon/daemon.go:270 +0x978
Oct 10 08:13:59 company dockerd[278]: goroutine 163 [runnable]:
Oct 10 08:13:59 company dockerd[278]: syscall.Syscall(0x76, 0xc6, 0x0, 0x0, 0x0, 0x0, 0x0)
Oct 10 08:13:59 company dockerd[278]: /build/buildroot/output/host/lib/go/src/syscall/asm_linux_arm.s:14 +0x8
Oct 10 08:13:59 company dockerd[278]: syscall.Fsync(0xc6, 0x16d8d5c, 0x40f7580)
Oct 10 08:13:59 company dockerd[278]: /build/buildroot/output/host/lib/go/src/syscall/zsyscall_linux_arm.go:449 +0x30
Oct 10 08:13:59 company dockerd[278]: internal/poll.(*FD).Fsync(0x40f7580, 0x0, 0x0)
Oct 10 08:13:59 company dockerd[278]: os.(*File).Sync(0x41b39b8, 0x16d6564, 0x4629c80)
Oct 10 08:13:59 company dockerd[278]: github.com/docker/docker/pkg/ioutils.(*atomicFileWriter).Close(0x4793080, 0x0, 0x0)
Oct 10 08:13:59 company dockerd[278]: github.com/docker/docker/container.(*Container).WriteHostConfig(0x4359040, 0x4a25900, 0x0, 0x0)
Oct 10 08:13:59 company dockerd[278]: github.com/docker/docker/container.(*Container).toDisk(0x4359040, 0x0, 0x0, 0x0)
Oct 10 08:13:59 company systemd[1]: docker.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
Oct 10 08:13:59 company dockerd[278]: github.com/docker/docker/container.(*Container).CheckpointTo(0x4359040, 0x18e79a8, 0x3c0ee98, 0x0, 0x0)
Oct 10 08:13:59 company dockerd[278]: github.com/docker/docker/daemon.(*Daemon).checkpointAndSave(0x3cf4d00, 0x4359040, 0x0, 0x0)
Oct 10 08:13:59 company dockerd[278]: github.com/docker/docker/daemon.(*Daemon).restore.func1(0x4901a00, 0x3cf4d00, 0x4901a10, 0x4576c80, 0x4576c60, 0x4576c40, 0x4359040)
The above is only a small portion of the actual output, which includes more instances of goroutine stacks.
After that, there are a few messages like the following:
Sep 06 12:10:02 company dockerd[476]: time="2019-09-06T12:10:02.712578011Z" level=warning msg="failed to load plugin io.containerd.snapshotter.v1.aufs" error="modprobe aufs failed: "modprobe: FATAL: Module aufs not found in directory /lib/modules/4.14
.66-v7\n": exit status 1"
Sep 06 12:10:02 company dockerd[476]: time="2019-09-06T12:10:02.712728688Z" level=info msg="loading plugin "io.containerd.snapshotter.v1.native"..." type=io.containerd.snapshotter.v1
Sep 06 12:10:02 company dockerd[476]: time="2019-09-06T12:10:02.712879261Z" level=info msg="loading plugin "io.containerd.snapshotter.v1.overlayfs"..." type=io.containerd.snapshotter.v1
Sep 06 12:10:02 company dockerd[476]: time="2019-09-06T12:10:02.713234365Z" level=info msg="loading plugin "io.containerd.snapshotter.v1.zfs"..." type=io.containerd.snapshotter.v1
Sep 06 12:10:02 company dockerd[476]: time="2019-09-06T12:10:02.714401709Z" level=warning msg="failed to load plugin io.containerd.snapshotter.v1.zfs" error="path /mnt/data/docker/containerd/daemon/io.containerd.snapshotter.v1.zfs must be a zfs filesy
stem to be used with the zfs snapshotter"
Sep 06 12:10:02 company dockerd[476]: time="2019-09-06T12:10:02.714484470Z" level=info msg="loading plugin "io.containerd.metadata.v1.bolt"..." type=io.containerd.metadata.v1
Sep 06 12:10:02 company dockerd[476]: time="2019-09-06T12:10:02.714582438Z" level=warning msg="could not use snapshotter aufs in metadata plugin" error="modprobe aufs failed: "modprobe: FATAL: Module aufs not found in directory /lib/modules/4.14.66-v7
\n": exit status 1"
Sep 06 12:10:02 company dockerd[476]: time="2019-09-06T12:10:02.714642178Z" level=warning msg="could not use snapshotter zfs in metadata plugin" error="path /mnt/data/docker/containerd/daemon/io.containerd.snapshotter.v1.zfs must be a zfs filesystem t
Sep 06 12:10:02 company dockerd[476]: time="2019-09-06T12:10:02.715197386Z" level=info msg="loading plugin "io.containerd.differ.v1.walking"..." type=io.containerd.differ.v1
Sep 06 12:10:02 company dockerd[476]: time="2019-09-06T12:10:02.715314105Z" level=info msg="loading plugin "io.containerd.gc.v1.scheduler"..." type=io.containerd.gc.v1
Sep 06 12:10:02 company dockerd[476]: time="2019-09-06T12:10:02.715483532Z" level=info msg="loading plugin "io.containerd.service.v1.containers-service"..." type=io.containerd.service.v1
Sep 06 12:10:02 company dockerd[295]: pc 0x76da4198
Sep 06 12:10:02 company dockerd[295]: cpsr 0x10
Sep 06 12:10:02 company dockerd[295]: fault 0x0
In these messages, the ones about aufs
failiing seem to be important (also because of the exit status 1
message, but they are marked as just warning
, so im not sure if they actually contribute to the issue.
After the stack traces, this shows up:
Oct 10 07:57:55 company dockerd[655]: time="2019-10-10T07:57:55.822297680Z" level=info msg="Graph migration to content-addressability took 0.00 seconds"
Oct 10 07:57:55 company dockerd[655]: time="2019-10-10T07:57:55.825508096Z" level=info msg="Loading containers: start."
Oct 10 07:57:56 company kernel: RTL871X: RTW_ADAPTIVITY_EN_
Oct 10 07:57:56 company kernel: AUTO, chplan:0x20, Regulation:3,3
Oct 10 07:57:56 company kernel: RTL871X: RTW_ADAPTIVITY_MODE_
Oct 10 07:57:56 company kernel: NORMAL
Oct 10 07:57:58 company kernel: RTL871X: nolinked power save leave
Oct 10 07:58:00 company dockerd[655]: runtime/cgo: pthread_create failed: Resource temporarily unavailable
Oct 10 07:58:00 company dockerd[655]: SIGABRT: abort
Oct 10 07:58:00 company dockerd[655]: PC=0x76da1198 m=2 sigcode=4294967290
Oct 10 07:58:00 company dockerd[655]: goroutine 0 [idle]:
Oct 10 07:58:00 company dockerd[655]: runtime: unknown pc 0x76da1198
Oct 10 07:58:01 company systemd[1]: docker.service: Start request repeated too quickly.
Oct 10 07:58:01 company systemd[1]: docker.service: Failed with result 'exit-code'.
Oct 10 07:58:01 company systemd[1]: Failed to start Docker Application Container Engine.
Oct 10 07:58:01 company systemd[1]: docker.socket: Failed with result 'service-start-limit-hit'.
Oct 10 07:58:27 company systemd[1]: Starting HassOS rauc good...
Noteworthy is the Resource temporarily unavailable
, which the internet says occurs when docker cannot spawn any more processes.
I’ve searched for possible solutions but nobody has addressed the cause of the issue and only applied a workaround, like reflashing the SD card. Reflashing the SD card is not an option, for one because we do not use an SD card, but also because the system is used in a production environment where user data has to be persisted at all times.
Similar topics I’ve found on the HomeAssistant Forum:
- Hassio won't start - "Failed to start Docker application container engine" (screenshot displays exactly the output I see as well)
- Hass.io won't boot. How can I recover my configuration files?
Any help to debug this issue would be great.
The way I see it, there are two problems here:
- docker crashing (maybe because of the number of processes it spawned? but our limit is set to 2021, so im not sure how it got that fast to that limit)
- docker crashing causes the reboot
Some details about the system:
- we only use HassOS, not HomeAssistant
- our storage is not an SD Card, it’s an eMMC
- docker version (taken from an unaffected system)
Client:
Version: v18.09.0
API version: 1.39
Go version: go1.11.4
Git commit: v18.09.0
Built: unknown-buildtime
OS/Arch: linux/arm
Experimental: false
Server:
Engine:
Version: 18.09.0
API version: 1.39 (minimum version 1.12)
Git commit:
Built: Mon Nov 18 17:22:36 UTC 2019
OS/Arch: linux/arm
Experimental: false
