Hi folks,
Just a small problem regarding vicare integration:
The error says
Logger: homeassistant.setup
Source: components/vicare/init.py:70
First occurred: 16:07:22 (1 occurrences)
Last logged: 16:07:22
Error during setup of component vicare
File “/usr/src/homeassistant/homeassistant/setup.py”, line 174, in _async_setup_component
component.setup, hass, processed_config # type: ignore
File “/usr/local/lib/python3.7/concurrent/futures/thread.py”, line 57, in run
File “/usr/src/homeassistant/homeassistant/components/vicare/init.py”, line 70, in setup
vicare_api = Device(conf[CONF_USERNAME], conf[CONF_PASSWORD], **params)
File “/usr/local/lib/python3.7/site-packages/PyViCare/PyViCareDevice.py”, line 40, in init
self.service = ViCareService(username, password, token_file, circuit)
File “/usr/local/lib/python3.7/site-packages/PyViCare/PyViCareService.py”, line 58, in init
self._getInstallations()
File “/usr/local/lib/python3.7/site-packages/PyViCare/PyViCareService.py”, line 219, in _getInstallations
self.id=self.installations[“entities”][0][“properties”][“id”]
KeyError: ‘entities’
- I’ve tried to reinstall vicare by deleting the configuration in configuration.yaml
- I’ve unsuccessfully tried to locate the files - but I’m on docker and have no Idea where the files are located
- I’ve restarted homeassistant
- I’ve updated to 107
Any Ideas for further analysis?
Greetings and Thanks in advance
Sebastian
