I’ve got the latest version of Hass.io (supervisor 150, HassOS 2.11) ova running in VirtualBox. Whenever I start any DNS add-on (AdGuard or Pi-hole), all add-ons and integrations can no longer contact the outside world. Looking through various logs I see messages such as:
tcp: lookup adguardteam.github.io on 172.30.32.2:53: read udp 172.30.32.1:39241->172.30.32.2:53: i/o timeout
[API] ConnectionError: HTTPConnectionPool(host='api.platformio.org', port=80): Max retries exceeded with url: /v2/lib/search?query=name%3A%22ESP8266WiFi%22 (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f4858b4c810>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution',)) (incremented retry: max=5, total=1)
I’ve followed the instructions to set up static IP and DNS for HassOS here with the DNS set to 1.1.1.1;8.8.8.8, and verified the settings with nmcli
in HassOS console.
nslookup
from HassOS works fine:
# time nslookup bing.com
Server: 1.1.1.1
Address: 1.1.1.1:53
Non-authoritative answer:
Address: 2620:1ec:c11::200
Address: 204.79.197.200
Address: 13.107.21.200
real 0m 0.02s
user 0m 0.00s
sys 0m 0.01s
However, nslookup
from the Hassio container is very slow:
core-ssh:~# time nslookup bing.com 172.30.32.2
Server: 172.30.32.2
Address 1: 172.30.32.2 hassio
Address 1: 204.79.197.200 a-0001.a-msedge.net
Address 2: 13.107.21.200
Address 3: 2620:1ec:c11::200
real 0m16.055s
user 0m0.000s
sys 0m0.002s
When I stop the DNS add-on nslookup
performs as expected, and all the other add-ons work:
Server: 172.30.32.2
real 0m0.098s
user 0m0.000s
sys 0m0.003s
Any ideas why running the DNS add-ons would cause DNS lookup to take so long, but only within Docker containers that shouldn’t even be using the DNS add-on?
