hello I am trying to start (first time) HA as a docjer on a centos 7 vm…the docker dies in few seconds. nthis is what I get from docker’s log:
File “/usr/local/lib/python3.7/runpy.py”, line 193, in _run_module_as_main
“main”, mod_spec)
File “/usr/local/lib/python3.7/runpy.py”, line 85, in _run_code
exec(code, run_globals)
File “/usr/src/homeassistant/homeassistant/main.py”, line 396, in
sys.exit(main())
File “/usr/src/homeassistant/homeassistant/main.py”, line 368, in main
args = get_arguments()
File “/usr/src/homeassistant/homeassistant/main.py”, line 105, in get_arguments
import homeassistant.config as config_util
File “/usr/src/homeassistant/homeassistant/config.py”, line 15, in
from homeassistant import auth
File “/usr/src/homeassistant/homeassistant/auth/init.py”, line 17, in
from .mfa_modules import auth_mfa_module_from_config, MultiFactorAuthModule
File “/usr/src/homeassistant/homeassistant/auth/mfa_modules/init.py”, line 10, in
from homeassistant import requirements, data_entry_flow
File “/usr/src/homeassistant/homeassistant/requirements.py”, line 9, in
import homeassistant.util.package as pkg_util
File “/usr/src/homeassistant/homeassistant/util/package.py”, line 12, in
from importlib_metadata import version, PackageNotFoundError
File “/usr/local/lib/python3.7/site-packages/importlib_metadata/init.py”, line 547, in
version = version(name)
File “/usr/local/lib/python3.7/site-packages/importlib_metadata/init.py”, line 509, in version
return distribution(distribution_name).version
File “/usr/local/lib/python3.7/site-packages/importlib_metadata/init.py”, line 482, in distribution
return Distribution.from_name(distribution_name)
File “/usr/local/lib/python3.7/site-packages/importlib_metadata/init.py”, line 183, in from_name
dist = next(dists, None)
File “/usr/local/lib/python3.7/site-packages/importlib_metadata/init.py”, line 452, in
return (item for item in root.iterdir()
File “/usr/local/lib/python3.7/pathlib.py”, line 1090, in iterdir
for name in self._accessor.listdir(self):
PermissionError: [Errno 13] Permission denied: ‘/config’
it looks like the last line might be the one…any suggestions?
