I am using the official HomeAssistant Docker image (0.75.3).
I have just tried adding hdmi_cec to the configuration.yaml with the following lines:
hdmi_cec:
devices:
Philips TV: 0.0.0.0
Bose SoundTouch 300: f.f.f.f
When I restart HomeAssistant, I get the following error traceback:
[homeassistant.setup] Error during setup of component hdmi_cec
File "/usr/local/lib/python3.6/site-packages/cec/__init__.py", line 18, in swig_import_helper
return importlib.import_module(mname)
File "/usr/local/lib/python3.6/importlib/__init__.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 994, in _gcd_import
File "<frozen importlib._bootstrap>", line 971, in _find_and_load
File "<frozen importlib._bootstrap>", line 953, in _find_and_load_unlocked
ModuleNotFoundError: No module named '_cec'
File "/usr/src/app/homeassistant/setup.py", line 148, in _async_setup_component
component.setup, hass, processed_config) # type: ignore
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/src/app/homeassistant/components/hdmi_cec.py", line 182, in setup
adapter = CecAdapter(name=display_name[:12], activate_source=False)
File "/usr/local/lib/python3.6/site-packages/pycec/cec.py", line 20, in __init__
import cec
File "/usr/local/lib/python3.6/site-packages/cec/__init__.py", line 21, in <module>
_cec = swig_import_helper()
File "/usr/local/lib/python3.6/site-packages/cec/__init__.py", line 20, in swig_import_helper
return importlib.import_module('_cec')
My hardware is as follows:
Running Pulse Eight USB CEC v1 (HDMI 1.4) firmware version 7 (latest) on /dev/ttyACM1. CEC Utils version 4.02.
Output from echo scan | cec-client -s -d 1:
opening a connection to the CEC adapter...
requesting CEC bus information ...
ERROR: [ 15288] failed to request the physical address
CEC bus information
device #0: TV
address: 0.0.0.0
active source: no
vendor: Philips
osd string: TV
CEC version: 1.4
power status: standby
language: ???
device #1: Recorder 1
address: 1.0.0.0
active source: no
vendor: Philips
osd string: CECTester
CEC version: 1.4
power status: on
language: eng
device #5: Audio
address: f.f.f.f
active source: no
vendor: Unknown
osd string: Audio
CEC version: unknown
power status: unknown
language: ???
currently active source: unknown (-1)
Any idea where I could be going wrong? Is something missing from the Docker image?
Thanks,
Daniel
