I’m trying to install RTL_433 to MQTT Bridge on a RPi 2 system running the Hass.io image. When I click the “Install” button, the spinning dots appear for around one minute until the button turns red. Nothing installs. Any help or leads would be appreciated. Here is the log output:
17-11-16 02:20:39 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/lib/python3.6/site-packages/aiohttp/web_protocol.py", line 416, in start
resp = yield from self._request_handler(request)
File "/usr/lib/python3.6/site-packages/aiohttp/web.py", line 323, in _handle
resp = yield from handler(request)
File "/usr/lib/python3.6/site-packages/hassio/api/util.py", line 31, in wrap_api
answer = await method(api, *args, **kwargs)
File "/usr/lib/python3.6/site-packages/hassio/addons/addon.py", line 474, in install
if not await self.docker.install(self.last_version):
File "/usr/lib/python3.6/site-packages/hassio/dock/util.py", line 18, in wrap_api
return await method(api, *args, **kwargs)
File "/usr/lib/python3.6/concurrent/futures/thread.py", line 55, in run
File "/usr/lib/python3.6/site-packages/hassio/dock/addon.py", line 219, in _install
return self._build(tag)
File "/usr/lib/python3.6/site-packages/hassio/dock/addon.py", line 232, in _build
image = self.docker.images.build(**build_env.get_docker_args(tag))
File "/usr/lib/python3.6/site-packages/docker/models/images.py", line 175, in build
raise BuildError(chunk['error'])
docker.errors.BuildError: The command '/bin/sh -c apk add --no-cache --virtual build-deps alpine-sdk cmake git libusb-dev && mkdir /tmp/src && cd /tmp/src && git clone git://git.osmocom.org/rtl-sdr.git && mkdir /tmp/src/rtl-sdr/build && cd /tmp/src/rtl-sdr/build && cmake ../ -DINSTALL_UDEV_RULES=ON -DDETACH_KERNEL_DRIVER=ON -DCMAKE_INSTALL_PREFIX:PATH=/usr/local && make && make install && chmod +s /usr/local/bin/rtl_* && cd /tmp/src/ && git clone https://github.com/james-fry/rtl_433 && cd rtl_433/ && mkdir build && cd build && cmake ../ && make && make install && apk del build-deps && rm -r /tmp/src && apk add --no-cache libusb mosquitto-clients jq' returned a non-zero code: 1
