Awesome work.
I recently started my setup and I am sticking with pure docker and was kind of lost for some until whole understanding of HA and hass.io
I will be setting up by docker without supervise.
@juan11perez I tried to open your docker-compose file from the hastebin.com link but it only shows an empty file. Is this file expired or deleted? Tried differerent browsers and no-content-blockers but it’s always empty. Would be great if you could share it again
Rene, i posted a link to a dropbox file at the end of my original post . I’ve added a number of dockers I use.
Hi Unfortunately I get the same as ReneM and the file is empty for me as well.
Ignore me I have just found the drop box line. Thanks
I wanted to go HASS + HA via Docker-Compose, here is what I used:
WD=/opt/hassio
mkdir -p $WD/{setup}
cd $WD/setup
cat << 'EOF' >docker-compose.yaml
version: '3.7'
services:
hassio_supervisor:
container_name: hassio_supervisor
image: "homeassistant/amd64-hassio-supervisor"
privileged: true
volumes:
- type: bind
source: ${SUPERVISOR_SHARE}
target: /data
- type: bind
source: /etc/machine-id
target: /etc/machine-id
- type: bind
source: /etc/localtime
target: /etc/localtime
- type: bind
source: /run/docker.sock
target: /run/docker.sock
- type: bind
source: /run/dbus
target: /run/dbus
- type: bind
source: /dev/bus/usb
target: /dev/bus/usb
security_opt:
- seccomp:unconfined
- apparmor:hassio-supervisor
environment:
- SUPERVISOR_SHARE=/opt/hassio
- SUPERVISOR_NAME=hassio_supervisor
- HOMEASSISTANT_REPOSITORY=homeassistant/qemux86-homeassistant
- DBUS_SYSTEM_BUS_ADDRESS=unix:path=/var/run/dbus/system_bus_socket
EOF
chmod +x docker-compose.yaml
More rambles here https://www.freesoftwareservers.com/display/FREES/Home-Assistant+-+Supervised+-+HASSIO+-+Docker-Compose
