I installed Ubuntu 18 on an ODROID N2 (aarch64). I have Docker installed and working. I can run home-assistant container and it works fine. I have Portainer container running. I have tasmoadmin container running.
I can run HASSIO supervisor and it works. Does make me a little nervous the whole “not supported” thing. But I get it.
What I would like to do is see if I can run this without the supervisor. It seems as though all the addons are based on the supervisor now so I am having trouble figuring out how to run them without it.
I have a running setup with HASSOS on an ODROID XU4 but it is very underpowered. I can see all the container information for each of the addons but still can’t seem to get them to run manually.
Ones I would really like to figure out are: configurator (file editor), DuckDNS and the Google Backup.
If anyone has information on running those manually can you please share? Or links to how or where to find non-supervisor versions?
Bottom line: I can run HASSIO supervisor and do it the easy way but I want to learn how all this works and get better at Docker. If you can’t run them without the supervisor then I’ll have to go that route.
I have been running HA the way you described for 2 years now.
Not HASSIO (HA+Supervisor) but simply HA in docker.
I install my own dockers and I manage them.
It works very well.
Happy to share my docker compose file for those containers if that’s how you’d like to proceed.
@juan11perez - in your docker-compose, you run a bunch of the containers as a userid 99 in groupid 100. Who is that? Is that a user you created and granted certain permissions?
i run these in unraid. this is the user unraid uses for containers.
in your case you need to run the command userid and that will give you your numbers
@juan11perez Thanks for providing your docker-compose file. It’s a great set of examples.
Like the OP, I installed HA via docker. A couple of places, the docs mention “addons are not supported except with the HassOS install method, but you can do it manually”. Those places don’t say how to do it manually. I was imagining it was by running the addons as docker containers and stitching them together, but I haven’t found any explicit documentation of that so far. Your info and examples show me what I need. It would be soooo handy if the HA docs gave at least a hint of what’s needed for “manually”.
I couldn’t find that quote in the documentation. What I did find is this:
the software from the add-ons may still usually be installed manually like any other program.
What that is saying is the software from the Node-Red Add-on can be installed manually. You can install Node-Red manually either as a Docker container or as an npm module.
Add-ons are curated applications that are packaged as customized docker containers (customized for use with the Supervisor container that comes with Home Assistant or Home Assistant Supervised).
So if you install Home Assistant or Home Assistant Supervised and want Node-Red, the easiest way is via the Node-Red Add-on. However, if you install Home Assistant Container and want Node-Red then you install the uncustomized, general release of Node-Red as a docker container or as an npm module.
Sorry, my quoted phrase was really just a paraphrase from memory. What I was looking at was this page: https://www.home-assistant.io/addons/, which says:
Add-ons are only available if you’ve used the Home Assistant installer. If you installed Home Assistant using any other method then you cannot use add-ons (but you can achieve the same result manually).
So, if I want to install the “Configurator” file editor manually, I’m left wondering if I really know what I’m supposed to do. Maybe if I’m the only one wondering, I’m just being dense. It wouldn’t be the first time.
The “File editor Add-on” is the Ace editor, which is an “embeddable code editor written in JavaScript”. It runs as a web app which means the Add-on contains the Ace editor hosted on a web server. All of this was put together by Frenck (i.e. he made a docker container with a web-server and the Ace editor and then customized it to work with the Add-on ecosystem).
I googled “Ace editor docker” and got some hits but I can’t attest to the usefulness of the results. Let’s just say that you picked an Add-on that isn’t commonly found as a general-release docker container (like Node-Red, mosquitto, Samba, etc).
Almost every add on is found as a docker, which you can install yourself.
If you want a webserved editor try cloud9, which I use.
The doctor compose is in my file.
I finally got an IntelNUC (NUC5i7RYH) on eBay so have gone to that running Ubuntu 20.04.
@juan11perez, I’ve been going through your docker file. So much more available than I ever thought!
I haven’t created my own docker-compose yet - I’ve just been doing docker run commands for now as I sort this all out and figure out what I want to run.
I have home-assistant running using mysql (mariadb). I have (had) a bunch of addons working and added them to the left-hand panel_iframe. It was all working well.
Then I switched off the old HASSOS system and moved to using the IntelNUC. When I changed the configuration to use my SSL certificate and domain then I lost my addons. HA works fine internally and externally. I even copied over the lovelace config and pointed all the devices and HA to the new MQTT container. But when I click on the icons for any of the addons I get nothing. Doesn’t even try and load them. I can only access HA via HTTPS now so I have a hunch that is the culprit. Event if I just try to access via the local hostname the addons won’t load. They do load independently via the local hostname and their listening ports but not via HA.
Is there something I need to do differently for the addons to work via HTTPS? They were working before when I was accessing using local address and HTTP.
sorry cant help with what’s now “Home Assistant”. I dont use that.
I run straight Home Assistant Container. The docker in my docker-compose substitute alll the addons.
I suspect that to see them externally (via https) you need to modify the addon configuration in HA to include a path to the certificate etc.
Right, that’s where I’m at. I’m running just the home-assistant container plus all the addons are independently run as containers as well with their ports exposed.
I added lines to the configuration.yaml to have icons show up in HA:
Not a bug, but something to consider. If you run HA under https:// , all iframes need to be https:// . So you need to make sure your other containers support https too. You can always install nginx to force them.
WOW a very long list for a docker compose. A complete set… I did use some mixed and docker and its also work. Currently running synology and RPI, but it should not be too far from ubuntu either. Maybe time for me to create a helping guide.
