Docker HASSIO Network with IPv6 enabled by default
When I want to use nginx ssl proxy over IPv6 and have auto IP banning up and running I have to reconfigure docker network in the haos:
systemctl stop hassos-supervisor
for ID in $(docker ps -a --format '{{ .ID }}'); do docker stop $ID; docker rm $ID; done;
docker network rm hassio
docker network create hassio -d bridge --ipv6 --subnet fd0c::/64 --subnet 172.30.32.0/23 --ip-range 172.30.33.0/24 --gateway 172.30.32.1 --opt com.docker.network.bridge.name=hassio
reboot
The important (new) part is:
Which enables ipv6 for containers. Without this setting, nginx will not get real IPv6 of the client who connectd and will get IPv4 of the docker network gateway instead. Guess nginx probably doesn’t like when you pass IPv6 in the forward headers when the connection from the docker network gateway to the container is done over IPv4.
So my feature request is: Can we have this by default?
Thanks and have fun!
Implemented in Add opt-in IPv6 for containers by davidrapan · supervisor#5879
