I have just started using Home Assistant and am trying to use an EnOcean USB dongle by adding the device /dev/ttyUSB0. However when I try and use it as my device, I get the error No valid dongle found for this path and the home assistant container shows the warning:
homeassistant | 2025-05-29 15:54:21.400 WARNING (SyncWorker_0) [homeassistant.components.enocean.dongle] Dongle path /dev/ttyUSB0 is invalid: [Errno 2] could not open port /dev/ttyUSB0: [Errno 2] No such file or directory: '/dev/ttyUSB0'
If I check for the /dev/ttyUSB0 within my container it does not exist.
root@curtis-VirtualBox:~# docker exec -it homeassistant ls -l /dev/ttyUSB0
ls: /dev/ttyUSB0: No such file or directory
However, checking on my Ubuntu 20.04 host /dev/ttyUSB0 does exist so I’m not sure why it is not being passed through to the container.
root@curtis-VirtualBox:~# ls -l /dev/ttyUSB0
-rwxrwxrwx 1 root root 36 May 29 16:23 /dev/ttyUSB0
Unplug the stick, then plug it back in, then execute: docker exec -it homeassistant dmesg. At the end of all that output should be events showing how the operating system dealt with the stick being plugged in. It should also show what /dev/X it attached to.
Don’t ever use that type of path to use a device in Home Assistant. There is a chance that it will swap usb0 to usb1 or another device on boot and mess everything up. Go to the hardware page and find the /dev/serial/by-id address and use that. It will work no matter what actual device it connects to.
docker exec -it homeassistant ls -l /dev/gpiochip1
crw------- 1 root root 254, 1 May 30 09:34 /dev/gpiochip1
However when I try to use /dev/gpiochip1 as the USB dongle path presents the same error in the UI and a new error in the home assistant container logs.
WARNING (SyncWorker_6) [homeassistant.components.enocean.dongle] Dongle path /dev/gpiochip1 is invalid: Could not configure port: (22, 'Invalid argument')
I have also tried plugging and unplugging the USB dongle a few times and then running docker exec -it homeassistant dmesg
This results in the following output which to me suggests that it is ttyUSB0 that should be used:
[ 1390.801618] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[ 1390.801648] ftdi_sio 3-2:1.0: device disconnected
[ 1392.590021] usb 3-2: new full-speed USB device number 9 using xhci_hcd
[ 1392.745234] usb 3-2: New USB device found, idVendor=0403, idProduct=6001, bcdDevice= 6.00
[ 1392.745241] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1392.745244] usb 3-2: Product: EnOcean USB 300 DC
[ 1392.745246] usb 3-2: Manufacturer: EnOcean GmbH
[ 1392.745248] usb 3-2: SerialNumber: FT3ZRIUV
[ 1392.748944] ftdi_sio 3-2:1.0: FTDI USB Serial Device converter detected
[ 1392.748992] usb 3-2: Detected FT232RL
[ 1392.749510] usb 3-2: FTDI USB Serial Device converter now attached to ttyUSB0
[ 1461.782891] usb 3-2: USB disconnect, device number 9
[ 1461.783359] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[ 1461.783392] ftdi_sio 3-2:1.0: device disconnected
[ 1463.275682] usb 3-2: new full-speed USB device number 10 using xhci_hcd
[ 1463.430988] usb 3-2: New USB device found, idVendor=0403, idProduct=6001, bcdDevice= 6.00
[ 1463.430995] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1463.430999] usb 3-2: Product: EnOcean USB 300 DC
[ 1463.431001] usb 3-2: Manufacturer: EnOcean GmbH
[ 1463.431004] usb 3-2: SerialNumber: FT3ZRIUV
[ 1463.434753] ftdi_sio 3-2:1.0: FTDI USB Serial Device converter detected
[ 1463.434800] usb 3-2: Detected FT232RL
[ 1463.435381] usb 3-2: FTDI USB Serial Device converter now attached to ttyUSB0
So if this is the output from the command: docker exec -it homeassistant dmesg then this should be what the container sees, and things looks good to me. It got assigned to /dev/ttyUSB0 and a driver ftdi_sio was assigned to it so that apps can communicate with it. Why the container can’t open it I don’t know.
Hopefully its not a file permissions problem? If you are running your Docker container as a regular user, the /dev/ttyUSB0 may not give your HA Docker permission to access it (check using ls -l /dev/ttyUSB0)
