Docker - home-assistant on RPi3 Get Started?
Is there a detailed Get Started for home-assistant on Docker RPi3? I’ve run the command on https://home-assistant.io/docs/installation/docker/#linux and restarted the Pi.
All seems to be installed correctly, but the home-assistant site on 8123 is not available.
What’s next?
Seems I’m missing a so basic step that I cannot find it anywhere…
There shouldn’t be more to it than that. Is there a homeassistant.log in your configuration directory? That should tell you what is happening.
I assume you are referring to the folder I’ve created to replace the “/path/to/your/config/”. I created the folder “/home/pi/DockerConfig” and it actually does not contain anything. Seems weird.
If helps, running docker ps -a returns:
CONTAINER ID        IMAGE                          COMMAND                  CREATED             STATUS                      PORTS               NAMES
fdb74d2e175b        homeassistant/home-assistant   "python -m homeass..."   11 minutes ago      Exited (1) 11 minutes ago                       home-assistant
