When I build a derivative Docker image ‘FROM homeassistant/home-assistant:0.108.0’ it fails to run. This also happened to me with v0.107.7. Everything works fine in v0.106.2.
I tried to file a defect against Hass.io, but I was told that was I was doing was not Hass.io.
Has anyone encountered this problem?
Is there an official place to file a defect against the Home Assistant Docker images?
[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] udev.sh: executing…
starting version 3.2.9
[15:46:02] INFO: Update udev information
[cont-init.d] udev.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
2020-04-08 15:46:04 INFO (MainThread) [homeassistant.bootstrap] Config directory: /config
2020-04-08 15:46:04 INFO (SyncWorker_0) [homeassistant.config] Upgrading configuration directory from 0.7.7 to 0.108.0
Testing configuration at /config
2020-04-08 15:46:05 INFO (SyncWorker_4) [homeassistant.loader] Loaded homeassistant from homeassistant.components.homeassistant
2020-04-08 15:46:05 INFO (MainThread) [homeassistant.setup] Setting up logger
[cmd] python exited 0
[cont-finish.d] executing container finish scripts…
[cont-finish.d] done.
[s6-finish] waiting for services.
s6-svscanctl: fatal: unable to control /var/run/s6/services: supervisor not listening
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
I have difficulties updating from 107.0 to 108.3 (actually I have been trying since 107.x without success).
I am using the addon to check the home assistant config and I also receive this error. I will try to update without my config, but I still have no clue why I can’t upgrade. Especially since there shouldn’t be any breaking changes from 107.0 to 107.x.
Log:
[16:24:04] INFO: Setup udev devices
[16:24:05] INFO: Don't worry, this temporary installation is not overwriting your current one.
[16:24:05] INFO: Installing Home Assistant: latest...
[16:24:05] INFO: Please be patient, this might take a few minutes...
[16:26:14] INFO: Installed Home Assistant 0.108.3
[16:26:14] INFO: Making a copy of your configuration for checking...
[16:34:36] INFO: Checking your configuration against this version...
[16:41:25] INFO: Configuration check finished - no error found! :)
[cont-finish.d] executing container finish scripts...
I got the same error “s6-svscanctl: fatal: unable to control /var/run/s6/services: supervisor not listening”
updated to “HassOS 3.12” tested again and it worked .
after that I dared to push update and it got though
Well, I just installed a brand new and fresh install of HA from the official image (deignated to be installed on Intel NUC). Installation went fine. Then I went to Supervisor/restart host, and bum - after NUC restart i got this in logs - HA is not availiable… I didn’t change anything in configuration - just restarted it just after was installed… So what is wrong ? At this point I have to put everything on hold - it is pointless to make a configuretion, when it will be not possible to restart …
Hi, I also installed home assistant supervised on my nuc recently and I have not managed to get past the initial installation process
marc@marc-NUC8i5BEH:~$ sudo ha core logs
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] udev.sh: executing...
[17:51:40] INFO: Update udev information
[cont-init.d] done.
[services.d] done.
Unable to find configuration. Creating default one in /config
[fix-attrs.d] done.
I’m stuck and I’m really new to containers. Could anybody help me please?
I run home assistant on Linux Mint. Had the same problem. I found somewhere that some guy wrote that disabling ipv6 solved his problem. I don’t use ipv6 so I disabled it in grub, update-grub, reboot and volla. No more errors.
Tailscale didnt work, there was always some connection errors in log but I couldn’t find the problem. Disabling ipv6 resolved all issues for now.
