I’ve just seen there are two different docker images on Docker Hub:
homeassistant/raspberrypi4-homeassistant
homeassistant/home-assistant
I can suppose the first one is customized for Raspberry Pi 4, but I couldn’t find information on what these customizations could be. Does anyone have information about them?
Regards,
It is as you supposed, drivers,etc for that specific hardware platform. Here are the details of all the docker images: The machine directory will show you the additional steps/libraries, etc it installs for the Pi on top of the base CPU architecture image…
Following that, I’ve checked the raspberrypi4 machine file and I see it installs GPIO, but I couldn’t make GPIO work with HassIO on my Raspberry 4. However, it worked without issues when I just deployed Home Assistant using Raspbian and Docker directly.
I guess then, there is some kind of problem with HassIO + this machine image.
