Running latest HA supervised install on a clean install of debian bullseye on odroid N2. From the systemctl status command I see a init-stage2 failed output related to docker.
│ ├─13561 /usr/bin/docker-proxy -proto tcp -host-ip 0.0.0.0 -host-port 5050 -container-ip 172.30.33.1 -container-port 5050
│ └─13568 /usr/bin/docker-proxy -proto tcp -host-ip :: -host-port 5050 -container-ip 172.30.33.1 -container-port 5050
├─polkit.service
│ └─7529 /usr/libexec/polkitd --no-debug
├─docker-99269a00000b14cc3718d354b435c180a7416ba30e5d1ba7564f2c6ce74b1643.scope …
│ ├─9516 s6-svscan -t0 /var/run/s6/services
│ ├─9597 foreground if /etc/s6/init/init-stage2-redirfd foreground if if s6-echo -n -- [s6-init] making user provided >
init-stage2 failed.
│ ├─9598 s6-supervise s6-fdholderd
│ ├─9609 foreground s6-setsid -gq -- with-contenv backtick -D 0 -n S6_LOGGING printcontenv S6_LOGGING importas S6_LOGGING S6_LOGGING>
│ └─9750 sleep infinity
├─docker-041eb3946701688d8021ac8eff69217266326543294800217d75743926fe9dc3.scope …
│ ├─14031 s6-svscan -t0 /var/run/s6/services
│ ├─14071 s6-supervise s6-fdholderd
Anyone have any thoughts on what could be causing this issue? Docker version 20.10.12, kernel version 5.15.26, ha version core-2022.3.2, supervisor version 2022.01.1.
