Docker Install on Unraid
I have been utilising Home Assistant on a RPi3 but would like to move to Home Assistant as a Docker container on Unraid. I followed the quide:
https://www.autohab.com/diy/2017/2/9/installing-home-assistant-on-unraid
However am receiving the message “This site can’t be reached” when select the WebUI.
Do I need to configure something else?
You can make it easier for yourself and use “network type” “host” instead. Otherwise, make sure that the 8123 port is forwarded correctly. I’m still on unraid 6.1 so my Docker menus look a bit different.
Mant thanks. Changed it to Host and it worked straight away.
