docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
1ca22351fa51 homeassistant/armv7-hassio-supervisor "/bin/entry.sh pytho…" 12 minutes ago Up 12 minutes hassio_supervisor
ac9b08f2b5fd homeassistant/armv7-hassio-dns:1 "coredns -conf /conf…" 13 minutes ago Up 12 minutes hassio_dns
But if I try to go the IP on :8123 it doesn’t show anything?
I just wanted to try out the ‘usb3 boot on rpi4’ method that Andreas Spiess showed, and it boots up nicely (starts on the SD and then switches to the USB ssd).
I wish RaspberryPi4 would be allowed to boot from the usb directly, but this seems like an ok workaround.
But I don’t see anything show up on port 8123?
Oh, firewall, dooh, that could very well be it. But as I said, I unfortunately had to abandon the attempts for now, before the WAF drops too low
But I’ll keep this in mind when I reattempt, I have the ssd and the sd ready for a new attempt.
Ok, I tried again now that the rest of the family is getting to bed
I started over, now I see the landing page, so something went wrong the first time.
But DARNED, that is fast now :-o
Can’t wait to see if I can get everything up and running…
Ok, so now I got a bit further. I’m currently trying to restore a backup. I can see most of the addon’s has restored, and started, such as the SSH addon, unifi controller, adguard, but so far not HA itself. I hope it will wake up soon…
Ok, that is weird. My Firefox kept complaining about bad communication, so I started chrome, and that started the HA UI immediately???
So after shutting down all the FF windows, I tried starting it again, and now it shows the UI.
So now it’s running on a RPi4 with a 240 GB USB3 SSD, it really helped on the speed.
I’m going to move the DB back to the RPi4, and now I will even consider adding the influxdb and grafana.
