Hi ,
I just started Home Assistant on a docker server using " ```
docker run -d --name=“home-assistant” -v /PATH_TO_YOUR_CONFIG:/config -v /etc/localtime:/etc/localtime:ro --net=host homeassistant/home-assistant
Looking at docker everything seems fine except that docker container ps shows nothing in the ports column. All other containers show their port mappings.
I started HA on another docker server and had exactly the same behavior. First start went fine and there were no problems to connect to HA. After stopping and restarting the container - the same problem.
Hints/resolutions would be very helpfull
thx in advance
