Hi fellows.
I’m experiencing trouble with my zigbee Gateway since integration lands out in frontend.
I have a odd configuration with my docker since I have a bridge for home assistant container to access it from reverse proxy. And a macvlan to give direct network access. I can’t use host mode since avahi port is already used.
Used to work with manual config. But integration won’t connect.
The integration system still discover it, but when I try to configure it, it can’t be able to connect despite using any or macvlan interface.
I don’t know how I can investigate further from that.
Any help appreciated.
Thanks in advance.
