Docker Monitor broken on Debian 11
Anyone having the same problem? I know the cause but so far have no solutions. Maybe some Debian guru here can help?
Debian 10 is running cgroup v1 which allows stats to be delivered as-is. However, Debian 11 is now running cgroup v2 which stops all the stats delivery. I believe since all of our OS will be upgraded this will broke everything. This even broke portainer stats monitoring.
I hope someone can help before it becomes a breaking changes
Do you mean running docker stats? Works here.
no It’s not that… for some of us who run monitor docker HACS. On Debian 11 due to changes on cgroup it won’t work anymore.
I believe you should open an Issue on their Github repo then.
HACS makes it very clear that the individual developer is responsible for their community offerings.
yeah done that… hoping someone from the community have a solution for this
