Hey everyone,
I’m moving my setup from an old RPi3 to a Docker Container on my main server and slowly learning how to live without add-ons.
So far so good and I’m really happy with the speed and some other aspects of a Docker HA.
One thing that I’ve run into is getting my weather station data into HA. I’ve got eclipse-Mosquitto container running and a rtl_433 container feeding from my SDR and both seem to be working.
However, I’m not getting any devices showing up in my HA instance of mosquitto. When I check the logs it shows up
Exception in async_discover when dispatching 'mqtt_discovery_new_sensor_mqtt': ({'device_class': 'humidity', 'name': 'Acurite Tower 13066 H', 'unit_of_measurement': '%', 'value_template': '{{ value|float }}', 'state_topic': 'rtl_433/Acurite-Tower/13066/A/humidity', 'unique_id': 'rtl433sensor13066H', 'availability_topic': 'rtl_433/status', 'expire_after': 'null', 'device': {'identifiers': '13066', 'name': '13066', 'model': 'Tower', 'manufacturer': 'Acurite'}, 'platform': 'mqtt'},) Traceback (most recent call last): File "/usr/src/homeassistant/homeassistant/components/mqtt/mixins.py", line 348, in async_discover config = discovery_schema(discovery_payload) File "/usr/local/lib/python3.10/site-packages/voluptuous/validators.py", line 232, in __call__ return self._exec((Schema(val) for val in self.validators), v) File "/usr/local/lib/python3.10/site-packages/voluptuous/validators.py", line 355, in _exec raise e if self.msg is None else AllInvalid(self.msg, path=path) File "/usr/local/lib/python3.10/site-packages/voluptuous/validators.py", line 351, in _exec v = func(v) File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 272, in __call__ return self._compiled([], data) File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 818, in validate_callable return schema(data) File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 272, in __call__ return self._compiled([], data) File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 595, in validate_dict return base_validate(path, iteritems(data), out) File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 433, in validate_mapping raise er.MultipleInvalid(errors) voluptuous.error.MultipleInvalid: expected int for dictionary value @ data['expire_after']
the Acuite-Tower is one of the devices I want to pull into HA but can’t figure out how to move forward.
Here is my docker-compose if that would be helpful but I feel that if I’m getting this error, the messages are getting to HA so there is something I need to do in HA?
version: '3.6'
services:
homeassistant:
container_name: homeassistant
image: "ghcr.io/home-assistant/home-assistant:stable"
volumes:
- /opt/HomeAssistant:/config
- /etc/localtime:/etc/localtime:ro
restart: unless-stopped
privileged: true
network_mode: bridge
ports:
- 8123:8123
depends_on:
- mosquitto
- acurite2mqtt
mosquitto:
image: eclipse-mosquitto
container_name: mosquitto
volumes:
- /opt/mosquitto:/mosquitto
ports:
- 1883:1883
- 9001:9001
acurite2mqtt:
container_name: acurite
image: colemamd/acurite2mqtt
devices:
- /dev/bus/usb/
volumes:
- /opt/acurite2mqtt/:/data/
