i get
docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
6155754edf95 homeassistant/home-assistant:0.64.3 “python -m homeassis…” 22 seconds ago Restarting (1) 3 seconds ago
but when i check
docker logs hass
standard_init_linux.go:190: exec user process caused “exec format error”
any ideas why docker doesn’t seem to like hass?
the docker hello world worked fine.
why would you expect that? just because the great majority of users start out on a raspberry Pi? where’s the fun in that? it’s much better for new users to start out on a new platform by pulling your hair out trying to figure out why it won’t work by following the documentation.
Do please use the Edit this page on GitHub link to add an edit providing a Raspberry Pi section with the relevant image in the command. Then somebody else can approve it.
I don’t know if you solved the problem but @elRadix’s suggestion is almost correct, you should use the homeassistant/raspberrypi3-homeassistant container. BUT, there is no latest tag, you must explicitly specify the version number you want:
homeassistant/raspberrypi3-homeassistant:0.68.0
All available version numbers can be found in Docker Hub.
I have edited the docs and submitted a pull request, it was approved this morning so I guess it will be made official with the next release.
hi @bonterra
i’m beginner in docker i want to build " pi_training " but i had same error,
where i can found the doc for edit line “homeassistant/raspberrypi3-homeassistant:0.68.0”
thanks
If using an RPi3, replace the last part with homeassistant/raspberrypi3-homeassistant:0.68.0 or any other version (the latest version right now is 0.70.1)
