I’m following the official HA guide to install it via Docker on a Raspberry Pi 5 Raspberry Pi - Home Assistant
I’ve got a fresh install of Raspbian for Raspberry Pi 5 (64 bits)
No device is plugged into the RPi5
I’m installing in the officially recommended way
The Raspberry Pi 5 is NOT supported currently in the full install method, I see no reason why it would be supported in the docker method either. It’s an architecture issue of the host, docker can’t fix that.
The reason Home Assistant OS doesn’t support it is down to the hardware. People are already using Docker on a Pi5 to run Home Assistant, an approach recommended by the developers.
It is on the official HO documentation to support bluetooth.
In the end it is an issue with jemalloc not working so I applied this fix Alternative - Home Assistant
It is not ideal since it is not optimized but at least it worked.
And I didn’t knew RPi5 was not supported yet tbh.
