Docker on RPI3 wont boot, error from 0.74.0 and on? -
Hi, I’m running Home Assistant on my RPI3 on Docker, but i’m still using 0.73.1 since I’m getting an error from 0.74.0 and on.
The log says
File “/usr/local/lib/python3.6/runpy.py”, line 193, in _run_module_as_main
main”, mod_spec)
File “/usr/local/lib/python3.6/runpy.py”, line 85, in _run_code
exec(code, run_globals)
File “/usr/local/lib/python3.6/site-packages/homeassistant/main.py”, line 377, in
sys.exit(main())
File “/usr/local/lib/python3.6/site-packages/homeassistant/main.py”, line 350, in main
attempt_use_uvloop()
File “/usr/local/lib/python3.6/site-packages/homeassistant/main.py”, line 28, in attempt_use_uvloop
import uvloop
File “/usr/local/lib/python3.6/site-packages/uvloop/init.py”, line 7, in
from .loop import Loop as __BaseLoop  # NOQA
File “uvloop/includes/stdlib.pxi”, line 31, in init uvloop.loop
AttributeError: module ‘asyncio’ has no attribute ‘ensure_future’
"__main__", mod_spec)
sys.exit(main())
import uvloop
What could this be?
Solved by deleting container and creating a new one with
docker run -d --name=“home-assistant” -v /path/to/your/config:/config -v /etc/localtime:/etc/localtime:ro --net=host homeassistant/raspberrypi3-homeassistant:0.75.1
