My Raspberry pi crashed and I had to rebuild. I decided to go with a Linux server (fresh image) running Ubuntu 16.02 LTE and use Docker.
I have docker running MQTT (more on that in a bit…) and Home-Assistant. I needed to run the openzwave control panel (aka ozwcp). That wasn’t found in the Home-Assistant docker image, so I started up the docker image Openzwave/openzwave-control-panel.
It sees my Aeontec 5 gen stick and found all the devices…Great! Saved it…umm WHERE does it go? There aren’t any paths mapped to the host system, I checked hub.docker.com.
Anyone know anything about this?
How do I find them? Can anyone give me a filename I could search for?
oh and BTW if you need to access a service in another container like mqtt, add link=mqtt:mqtt and then change the hostname from servername.com to mqtt.
here are my startup files for the images, for the next guy…
There is no config directory in the OZWCP docker… everything (config / executables / etc) is in the same directory. What you have to do is override the individual files you want to share with other containers. Do something like this.
Can you define unknown type?
Do you see data returned?(sensor value or boolean)
Zwave kinda just worked for me.
Have you tried configuring in Open Zwave Control Panel?
In OZCP you should be seeing data and sensor type.(I believe, been a while since I looked at that)
HA should not be running when connecting to OZCP if I remember correctly.
