Docker Reverse Proxy Unable to connect to Home Assistant
I have an existing LetsEncrypt container and am trying to setup Home Assistant via the LinuxServer Docker image. I am able to access Home Assistant via IP address from within my network, but when I try to access via URL, I get the login page that accepts my login information (and apparently validates it). When I login, I just see “Unable to connect to Home Assistant.” from both inside and outside my network, private tabs, and Android app. Nothing in logs, until the 3rd retry where I get the following in my logs:
2021-10-04 22:16:34 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from {pfsense} (192.168.1.1). (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/94.0.4606.61 Safari/537.36)
Any relevant logs I can look at or ideas why things aren’t loading?
Relevant configuration.yml:
http:
  ip_ban_enabled: false
  use_x_forwarded_for: true
  trusted_proxies:
    - 172.17.0.2
    - 192.168.1.100
    - 127.0.0.1
    - 192.168.1.1
    - 0.0.0.0
Likely an issue with websockets in your reverse proxy configuration
I used the template provided in the LInuxserver/LetsEncrypt Docker image:
## Version 2020/12/09
# make sure that your dns has a cname set for homeassistant and that your homeassistant container is not using a base url
server {
    listen 443 ssl;
    listen [::]:443 ssl;
    server_name homeassistant.*;
    include /config/nginx/ssl.conf;
    client_max_body_size 0;
    # enable for ldap auth, fill in ldap details in ldap.conf
    #include /config/nginx/ldap.conf;
    # enable for Authelia
    #include /config/nginx/authelia-server.conf;
    location / {
        # enable the next two lines for http auth
        #auth_basic "Restricted";
        #auth_basic_user_file /config/nginx/.htpasswd;
        # enable the next two lines for ldap auth
        #auth_request /auth;
        #error_page 401 =200 /ldaplogin;
        #include /config/nginx/authelia-location.conf;
        include /config/nginx/proxy.conf;
        resolver 127.0.0.11 valid=30s;
        set $upstream_app homeassistant;
        set $upstream_port 8123;
        set $upstream_proto http;
        proxy_pass $upstream_proto://192.168.1.100:$upstream_port;
    location /api {
        proxy_pass $upstream_proto://$upstream_app:$upstream_port;
Last one needs to be adjusted too :
server {
    listen 443 ssl;
    location / {
    location /api {
Whoops, missed that proxy_pass in /api. Looks like the issue persists though after that change (and restarting both containers)
Thanks for the tip; got me looking in the right direction and I solved my problem after some research led me to: https://www.nginx.com/blog/websocket-nginx/ .
Adding the following to the server config worked!
    proxy_set_header Upgrade $http_upgrade;
    proxy_set_header Connection "Upgrade";
    proxy_set_header Host $host;
Here’s the working site config for anyone who comes across a similar issue:
server {
    listen 443 ssl;
    location / {
    location /api {
Thank you very much for this :slight_smile:
