Hello guys. I had a post up to try and solve my problem. I will qoute this first if it helps.
Hey guys I know you want to redirect me to [http-homassistant help] but I tried and I think I miss something. Hope you can help me. If I do not give every fact needed for solving pls say what it is and maybe where to find it.
System and Software:
Homeassistant in Docker (image)
Nginx Proxy Manager (NPM) (image)
My configuration.yaml without any changes:
# Loads default set of integrations. Do not remove.
default_config:
# Text to speech
tts:
- platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yamlEdited to fit the help-page:
default_config:
# Text to speech
tts:
http:
use_x_forwarded_for: true
trusted_proxies:
- [IP of Proxyserver in Docker]
- [also tried IP of Proxy in Docker as range (IP/24)]
- [also tried Domain]Edited to fit forum comments
Same as above but with a
DOMAINmodifier which did not work either.In every case it got into restricted mode or showed “This computer is not allowed” one time.
I did a reboot between all changes and my pattern of access is:
Home network: http://[IP]:8123
Outside of home network: https://[DOMAIN]Further information:
on NPM:
Force SSL and HSTS are enabledHope you can help me thanks a lot
Now I am stuck with the "Unable to connect to Home Assistant. Retrying in [XX] seconds… " screen. I modified my config and now i looks like this:
default_config:
# Text to speech
tts:
homeassistant:
auth_providers:
- type: homeassistant
- type: trusted_networks
trusted_networks:
- 192.168.0.0/16
- 172.22.0.0/16
- 127.0.0.1
- ::1
# URL
external_url: [MY_DOMAIN]
internal_url: [MY_IP:PORT]
http:
trusted_proxies:
- 192.168.0.0/16
- 172.22.0.2
- 127.0.0.1
- ::1
This is the full configuration.yaml
Every time I want to log in it states wrong login credentials in log like this:
Logger: homeassistant.components.http.ban
Source: components/http/ban.py:82
Integration: HTTP (documentation, issues)
First occurred: 18:15:18 (13 occurrences)
Last logged: 21:28:15
Login attempt or request with invalid authentication from [MY_WAN]. Requested URL: '/auth/token'. (Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:106.0) Gecko/20100101 Firefox/106.0)
Despite my entering the right credentials.
I really hope i can get it running with your help.
Thanks to every reply in advance
