Hi there,
I switched to running HA in Docker recently. Now, I am trying to set up all my entities again. I’m trying to set up the fritzbox_callmonitor
according to the guide:
However, there is no such integration as indicated there. I only have the following:
So, I select the callmonitor and get the following error:
2021-02-27 23:50:13 INFO (SyncWorker_2) [homeassistant.util.package] Attempting install of fritzconnection==0.8.4
2021-02-27 23:50:34 ERROR (SyncWorker_2) [homeassistant.util.package] Unable to install package fritzconnection==0.8.4: ERROR: Command errored out with exit status 1:
command: /usr/local/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-hqznxm__/lxml/setup.py'"'"'; __file__='"'"'/tmp/pip-install-hqznxm__/lxml/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-r30isly1
cwd: /tmp/pip-install-hqznxm__/lxml/
Complete output (89 lines):
Building lxml version 4.3.4.
Building without Cython.
ERROR: b'/bin/sh: xslt-config: not found\n'
** make sure the development packages of libxml2 and libxslt are installed **
Using build configuration of libxslt
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-x86_64-3.8
creating build/lib.linux-x86_64-3.8/lxml
copying src/lxml/doctestcompare.py -> build/lib.linux-x86_64-3.8/lxml
copying src/lxml/ElementInclude.py -> build/lib.linux-x86_64-3.8/lxml
copying src/lxml/builder.py -> build/lib.linux-x86_64-3.8/lxml
copying src/lxml/pyclasslookup.py -> build/lib.linux-x86_64-3.8/lxml
copying src/lxml/cssselect.py -> build/lib.linux-x86_64-3.8/lxml
copying src/lxml/__init__.py -> build/lib.linux-x86_64-3.8/lxml
copying src/lxml/usedoctest.py -> build/lib.linux-x86_64-3.8/lxml
copying src/lxml/_elementpath.py -> build/lib.linux-x86_64-3.8/lxml
copying src/lxml/sax.py -> build/lib.linux-x86_64-3.8/lxml
creating build/lib.linux-x86_64-3.8/lxml/includes
copying src/lxml/includes/__init__.py -> build/lib.linux-x86_64-3.8/lxml/includes
creating build/lib.linux-x86_64-3.8/lxml/html
copying src/lxml/html/_html5builder.py -> build/lib.linux-x86_64-3.8/lxml/html
copying src/lxml/html/ElementSoup.py -> build/lib.linux-x86_64-3.8/lxml/html
copying src/lxml/html/_setmixin.py -> build/lib.linux-x86_64-3.8/lxml/html
copying src/lxml/html/_diffcommand.py -> build/lib.linux-x86_64-3.8/lxml/html
copying src/lxml/html/clean.py -> build/lib.linux-x86_64-3.8/lxml/html
copying src/lxml/html/builder.py -> build/lib.linux-x86_64-3.8/lxml/html
copying src/lxml/html/defs.py -> build/lib.linux-x86_64-3.8/lxml/html
copying src/lxml/html/diff.py -> build/lib.linux-x86_64-3.8/lxml/html
copying src/lxml/html/__init__.py -> build/lib.linux-x86_64-3.8/lxml/html
copying src/lxml/html/usedoctest.py -> build/lib.linux-x86_64-3.8/lxml/html
copying src/lxml/html/soupparser.py -> build/lib.linux-x86_64-3.8/lxml/html
copying src/lxml/html/html5parser.py -> build/lib.linux-x86_64-3.8/lxml/html
copying src/lxml/html/formfill.py -> build/lib.linux-x86_64-3.8/lxml/html
creating build/lib.linux-x86_64-3.8/lxml/isoschematron
copying src/lxml/isoschematron/__init__.py -> build/lib.linux-x86_64-3.8/lxml/isoschematron
copying src/lxml/etree.h -> build/lib.linux-x86_64-3.8/lxml
copying src/lxml/etree_api.h -> build/lib.linux-x86_64-3.8/lxml
copying src/lxml/lxml.etree.h -> build/lib.linux-x86_64-3.8/lxml
copying src/lxml/lxml.etree_api.h -> build/lib.linux-x86_64-3.8/lxml
copying src/lxml/includes/xmlschema.pxd -> build/lib.linux-x86_64-3.8/lxml/includes
copying src/lxml/includes/xslt.pxd -> build/lib.linux-x86_64-3.8/lxml/includes
copying src/lxml/includes/etreepublic.pxd -> build/lib.linux-x86_64-3.8/lxml/includes
copying src/lxml/includes/schematron.pxd -> build/lib.linux-x86_64-3.8/lxml/includes
copying src/lxml/includes/xmlparser.pxd -> build/lib.linux-x86_64-3.8/lxml/includes
copying src/lxml/includes/xmlerror.pxd -> build/lib.linux-x86_64-3.8/lxml/includes
copying src/lxml/includes/relaxng.pxd -> build/lib.linux-x86_64-3.8/lxml/includes
copying src/lxml/includes/c14n.pxd -> build/lib.linux-x86_64-3.8/lxml/includes
copying src/lxml/includes/htmlparser.pxd -> build/lib.linux-x86_64-3.8/lxml/includes
copying src/lxml/includes/uri.pxd -> build/lib.linux-x86_64-3.8/lxml/includes
copying src/lxml/includes/xpath.pxd -> build/lib.linux-x86_64-3.8/lxml/includes
copying src/lxml/includes/__init__.pxd -> build/lib.linux-x86_64-3.8/lxml/includes
copying src/lxml/includes/dtdvalid.pxd -> build/lib.linux-x86_64-3.8/lxml/includes
copying src/lxml/includes/tree.pxd -> build/lib.linux-x86_64-3.8/lxml/includes
copying src/lxml/includes/xinclude.pxd -> build/lib.linux-x86_64-3.8/lxml/includes
copying src/lxml/includes/config.pxd -> build/lib.linux-x86_64-3.8/lxml/includes
copying src/lxml/includes/lxml-version.h -> build/lib.linux-x86_64-3.8/lxml/includes
copying src/lxml/includes/etree_defs.h -> build/lib.linux-x86_64-3.8/lxml/includes
creating build/lib.linux-x86_64-3.8/lxml/isoschematron/resources
creating build/lib.linux-x86_64-3.8/lxml/isoschematron/resources/rng
copying src/lxml/isoschematron/resources/rng/iso-schematron.rng -> build/lib.linux-x86_64-3.8/lxml/isoschematron/resources/rng
creating build/lib.linux-x86_64-3.8/lxml/isoschematron/resources/xsl
copying src/lxml/isoschematron/resources/xsl/RNG2Schtrn.xsl -> build/lib.linux-x86_64-3.8/lxml/isoschematron/resources/xsl
copying src/lxml/isoschematron/resources/xsl/XSD2Schtrn.xsl -> build/lib.linux-x86_64-3.8/lxml/isoschematron/resources/xsl
creating build/lib.linux-x86_64-3.8/lxml/isoschematron/resources/xsl/iso-schematron-xslt1
copying src/lxml/isoschematron/resources/xsl/iso-schematron-xslt1/iso_schematron_skeleton_for_xslt1.xsl -> build/lib.linux-x86_64-3.8/lxml/isoschematron/resources/xsl/iso-schematron-xslt1
copying src/lxml/isoschematron/resources/xsl/iso-schematron-xslt1/iso_schematron_message.xsl -> build/lib.linux-x86_64-3.8/lxml/isoschematron/resources/xsl/iso-schematron-xslt1
copying src/lxml/isoschematron/resources/xsl/iso-schematron-xslt1/iso_abstract_expand.xsl -> build/lib.linux-x86_64-3.8/lxml/isoschematron/resources/xsl/iso-schematron-xslt1
copying src/lxml/isoschematron/resources/xsl/iso-schematron-xslt1/iso_dsdl_include.xsl -> build/lib.linux-x86_64-3.8/lxml/isoschematron/resources/xsl/iso-schematron-xslt1
copying src/lxml/isoschematron/resources/xsl/iso-schematron-xslt1/iso_svrl_for_xslt1.xsl -> build/lib.linux-x86_64-3.8/lxml/isoschematron/resources/xsl/iso-schematron-xslt1
copying src/lxml/isoschematron/resources/xsl/iso-schematron-xslt1/readme.txt -> build/lib.linux-x86_64-3.8/lxml/isoschematron/resources/xsl/iso-schematron-xslt1
running build_ext
building 'lxml.etree' extension
creating build/temp.linux-x86_64-3.8
creating build/temp.linux-x86_64-3.8/src
creating build/temp.linux-x86_64-3.8/src/lxml
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -fno-semantic-interposition -fno-builtin-malloc -fno-builtin-calloc -fno-builtin-realloc -fno-builtin-free -ljemalloc -DTHREAD_STACK_SIZE=0x100000 -fPIC -DCYTHON_CLINE_IN_TRACEBACK=0 -Isrc -Isrc/lxml/includes -I/usr/local/include/python3.8 -c src/lxml/etree.c -o build/temp.linux-x86_64-3.8/src/lxml/etree.o -w
unable to execute 'gcc': No such file or directory
Compile failed: command 'gcc' failed with exit status 1
creating tmp
cc -I/usr/include/libxml2 -c /tmp/xmlXPathInitotm8zb3f.c -o tmp/xmlXPathInitotm8zb3f.o
unable to execute 'cc': No such file or directory
Could not find function xmlCheckVersion in library libxml2. Is libxml2 installed?
error: command 'gcc' failed with exit status 1
ERROR: Failed building wheel for lxml
command: /usr/local/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-hqznxm__/lxml/setup.py'"'"'; __file__='"'"'/tmp/pip-install-hqznxm__/lxml/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-tz10xvd8/install-record.txt --single-version-externally-managed --compile --install-headers /usr/local/include/python3.8/lxml
Complete output (88 lines):
running install
running build
running build_py
creating build
running build_ext
cc -I/usr/include/libxml2 -c /tmp/xmlXPathInitpkuq_3jg.c -o tmp/xmlXPathInitpkuq_3jg.o
ERROR: Command errored out with exit status 1: /usr/local/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-hqznxm__/lxml/setup.py'"'"'; __file__='"'"'/tmp/pip-install-hqznxm__/lxml/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-tz10xvd8/install-record.txt --single-version-externally-managed --compile --install-headers /usr/local/include/python3.8/lxml Check the logs for full command output.
WARNING: You are using pip version 20.2.4; however, version 21.0.1 is available.
You should consider upgrading via the '/usr/local/bin/python3 -m pip install --upgrade pip' command.
2021-02-27 23:50:34 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 422, in _handle_request
resp = await self._request_handler(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_app.py", line 499, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_middlewares.py", line 118, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 56, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 18, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 72, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 127, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 129, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 136, in post
return await super().post(request)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 60, in wrapper
result = await method(view, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 69, in post
result = await self._flow_mgr.async_init(
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 119, in async_init
flow = await self.async_create_flow(handler, context=context, data=data)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 541, in async_create_flow
await async_process_deps_reqs(self.hass, self._hass_config, integration)
File "/usr/src/homeassistant/homeassistant/setup.py", line 343, in async_process_deps_reqs
await requirements.async_get_integration_with_requirements(
File "/usr/src/homeassistant/homeassistant/requirements.py", line 79, in async_get_integration_with_requirements
await async_process_requirements(
File "/usr/src/homeassistant/homeassistant/requirements.py", line 136, in async_process_requirements
raise RequirementsNotFound(name, [req])
homeassistant.requirements.RequirementsNotFound: Requirements for fritzbox_callmonitor not found: ['fritzconnection==0.8.4'].
Is this just me? Or has anyone seen this before and can point me to the (hopefully obvious) solution?
Thanks!
Andreas
