I am running Home Assistant in a docker with this command:
docker run -d --name="home-assistant" -v /home/sander/hass/homeassistant:/config -v /etc/localtime:/etc/localtime:ro --device /dev/ttyACM0:/dev/ttyACM0 --net=host homeassistant/home-assistant
Now, I want to upgrade to current latest version (0.64.3 as we speak):
docker stop home-assistant
docker pull homeassistant/home-assistant:0.64.3
docker start home-assistant
After that, I’ve checked the running containers.
balk@ubakfiets:~/hass$ docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
xxxxxxxxxxx xxxxxxxxxxxxx "python -m homeassis…" 2 weeks ago Up 15 minutes home-assistant
I even ran the update again:
0.64.3: Pulling from homeassistant/home-assistant
Digest: sha256:7c9aa876c813cf8e0b8025336bc6bb68f03dd7b22d331d605de8074485490f3a
Status: Image is up to date for homeassistant/home-assistant:0.64.3
But the version of Home Assistant starting is an older one:
2018-03-04 00:22:48 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.current_version, old_state=None,
new_state=<state sensor.current_version=0.63.2; friendly_name=Current Version
Does anyone know what is going on here? According to systemctl
there is no other instance running.
