Hass.io is getting more unstable by the day and some days it runs fine without any issues.
The webinterface responds fast for a long time but after a while it is freezing randomly.
I found a few notes in the different topics on the forum about large databases. With that info I moved the database to a Synology NAS and looked fine. But… The issues came up again.
Then shortened the database to 3 days. Looked fine, but… again strange behavior happens.
This instance runs on a RPi3B+ with a Samsung 32G card. RFXtrx, USB to RS485 and a USB to serial converter for a DSMR.
Wired to ethernet and using a original RPi power adapter.
A snippet of the log:
18-12-27 18:47:02 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
18-12-27 19:00:11 WARNING (SyncWorker_13) [urllib3.connectionpool] Connection pool is full, discarding connection: localhost
18-12-27 19:00:11 WARNING (SyncWorker_6) [urllib3.connectionpool] Connection pool is full, discarding connection: localhost
18-12-27 19:00:11 WARNING (SyncWorker_18) [urllib3.connectionpool] Connection pool is full, discarding connection: localhost
18-12-27 19:00:12 ERROR (MainThread) [hassio.homeassistant] Error on call http://172.30.32.1:8123/api/: Cannot connect to host 172.30.32.1:8123 ssl:None [Connection refused]
18-12-27 19:00:12 WARNING (MainThread) [hassio.tasks] Watchdog miss API response from Home Assistant
18-12-27 19:00:13 WARNING (SyncWorker_5) [urllib3.connectionpool] Connection pool is full, discarding connection: localhost
18-12-27 19:00:13 WARNING (SyncWorker_3) [urllib3.connectionpool] Connection pool is full, discarding connection: localhost
18-12-27 19:00:13 WARNING (SyncWorker_17) [urllib3.connectionpool] Connection pool is full, discarding connection: localhost
18-12-27 19:00:13 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker!
18-12-27 19:00:13 WARNING (SyncWorker_10) [urllib3.connectionpool] Connection pool is full, discarding connection: localhost
18-12-27 19:00:13 ERROR (MainThread) [hassio.utils] Can’t execute start while a task is in progress
18-12-27 19:00:13 INFO (SyncWorker_14) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant Docker application
18-12-27 19:00:15 INFO (SyncWorker_14) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.84.5
18-12-27 19:00:55 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
18-12-27 19:18:07 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
18-12-27 19:29:27 ERROR (MainThread) [hassio.homeassistant] Error on call http://172.30.32.1:8123/api/: Cannot connect to host 172.30.32.1:8123 ssl:None [Connection refused]
18-12-27 19:29:27 ERROR (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant API!
18-12-27 19:29:28 INFO (SyncWorker_3) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant Docker application
18-12-27 19:29:28 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker!
18-12-27 19:29:28 ERROR (MainThread) [hassio.utils] Can’t execute start while a task is in progress
18-12-27 19:29:30 INFO (SyncWorker_9) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.84.5
18-12-27 19:30:10 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
18-12-27 19:36:03 ERROR (MainThread) [hassio.homeassistant] Error on call http://172.30.32.1:8123/api/: Cannot connect to host 172.30.32.1:8123 ssl:None [Connection refused]
18-12-27 19:36:03 WARNING (MainThread) [hassio.tasks] Watchdog miss API response from Home Assistant
18-12-27 19:36:15 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker!
18-12-27 19:36:15 INFO (SyncWorker_5) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant Docker application
18-12-27 19:36:18 INFO (SyncWorker_5) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.84.5
18-12-27 19:36:58 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
18-12-27 19:41:38 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker!
18-12-27 19:41:38 INFO (SyncWorker_5) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant Docker application
18-12-27 19:41:42 INFO (SyncWorker_5) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.84.5
18-12-27 19:42:22 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
18-12-27 19:47:17 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker!
18-12-27 19:47:17 INFO (SyncWorker_7) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant Docker application
18-12-27 19:47:18 INFO (SyncWorker_7) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.84.5
18-12-27 19:47:59 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
18-12-27 19:48:44 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
What could be the issue or can be a solution?
