I’m a new user of HA and I’m trying to set up zigbee2mqtt.
Home assistant, Mosquitto and zigbee2mqtt are all running in docker on a Synology NAS. I have a Sonoff USB 3.0 dongle which I have re-flashed with Koenkk CC1352P2_CC2652P_launchpad_coordinator_20220219 firmware.
I can successfully link a couple of Zigbee smart plugs using ZHA. However, as soon as I try to start zigbee2mqtt, it fails (logs below) and prevents ZHA from communicating with the previously working Zigbee devices.
For a short time I did have a device connected through zigbee2mqtt (as can be seen in the configuration.yaml), but I did something that now causes the whole process to fail. Stupidly I wasn’t doing one thing at a time and noting it all down. Unfortunately being new to the Zigbee devices and HA I’m now rather flailing in the dark!
docker-compose.yml:
version: '3.8'
services:
mqtt:
image: eclipse-mosquitto:2.0
restart: unless-stopped
volumes:
- "./mosquitto-data:/mosquitto"
ports:
- "1883:1883"
- "9001:9001"
command: "mosquitto -c /mosquitto-no-auth.conf"
zigbee2mqtt:
container_name: zigbee2mqtt
image: koenkk/zigbee2mqtt
volumes:
- ./zigbee2mqtt-data:/app/data
- /run/udev:/run/udev:ro
ports:
- 8080:8080
environment:
- TZ=Europe/London
devices:
- /dev/ttyUSB0:/dev/ttyUSB0
configuration.yaml
permit_join: true
mqtt:
base_topic: zigbee2mqtt
server: mqtt://mqtt
serial:
port: /dev/ttyUSB0
frontend:
port: 8080
homeassistant: true
advanced:
network_key:
- 53
- 226
devices:
'0xb4e3f9fffebda8cd':
friendly_name: 'TRV Andy Study'
In the log I get messages:
info 2022-06-06 15:43:20: Logging to console and directory: '/app/data/log/2022-06-06.15-43-18' filename: log.txt
info 2022-06-06 15:43:21: Starting Zigbee2MQTT version 1.25.1 (commit #3f6a137)
info 2022-06-06 15:43:21: Starting zigbee-herdsman (0.14.27)
error 2022-06-06 15:43:42: Error while starting zigbee-herdsman
error 2022-06-06 15:43:42: Failed to start zigbee
error 2022-06-06 15:43:42: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
error 2022-06-06 15:43:42: Exiting...
error 2022-06-06 15:43:42: Error: SRSP - SYS - getExtAddr after 6000ms
at Timeout._onTimeout (/app/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35)
at listOnTimeout (node:internal/timers:559:17)
at processTimers (node:internal/timers:502:7)
info 2022-06-06 15:43:51: Logging to console and directory: '/app/data/log/2022-06-06.15-43-49' filename: log.txt
info 2022-06-06 15:43:51: Starting Zigbee2MQTT version 1.25.1 (commit #3f6a137)
info 2022-06-06 15:43:51: Starting zigbee-herdsman (0.14.27)
error 2022-06-06 15:43:53: Failed to call 'Frontend' 'stop' (TypeError: Cannot read properties of null (reading 'clients')
at Frontend.stop (/app/lib/extension/frontend.ts:59:39)
at Controller.callExtensions (/app/lib/controller.ts:316:40)
at Controller.stop (/app/lib/controller.ts:191:9)
at stop (/app/index.js:114:5)
at process.handleQuit (/app/index.js:120:9))
I looked at the suggested link, but as I’d already reflashed the dongle, and have access to the port for ZHA I could see how it would help.
Any help would be gratefully received.
