What is proper config path for zwave when using HA docker image?
HA logs keeps showing it can’t find files the config files.
Do I need to mount (-v) volume and add the files to the folder or leave it unmounted and they reside in container?
I use below path but not working
config_path: /usr/local/share/python-openzwave/config
The configuration files are stored in the /config folder.
In order to have my ZWave USB dongle pointing to /dev/zwave on my host OS, I created a file named /etc/udev/rules.d/10-zwave-static.rules, containing a single line:
I have usb symlink but I read docker may not handle udev correctly or is a little nonstandard here.
thank you for pointing that out. I will watch for that.
I don’t get why you specify the config_path option: do you really need a specific folder? Letting hass store ZWave files in its config folder (default config_path value) works perfectly, if you don’t have specific needs. Even with Docker.
HASS was failing to start when I enabled zwave without config folder specified. With config folder specified it started but component would fail start.
