I reported this problem (4 days ago) in HomeAssistant.io’s GitHub repo but it hasn’t been acknowledged yet.
The documentation’s search function does not work. Normally it displays an input-box where you can enter your search string but now it displays nothing.
I tried three different browsers with the same result. The absence of a search function makes it more challenging to find information.
Yes, I’m using pi-hole to block ads but I don’t understand how that would cause this issue. The do see the magnifying icon and its URL is https://www.home-assistant.io/# which is not blocked by my pi-hole.
I’ve tried the following browsers (none have additional ad-blocking software) with the same results:
Firefox on Android
Chrome on Android
Firefox on Linux
Edge on Windows
I’ve checked pi-hole’s logs and there’s no report of any blocked requests related to https://www.home-assistant.io.
I definitely do no not see the screenshot you posted. All I see is the magnifying glass becomes selected:
My complete guess is that your Pi-Hole (or some other browser extension/adblocker) is blocking that Algolia logo (or javascript) and then causing the other UI elements to not display as well.
I know that Paulus updated the search exactly a week ago to make it now search through Integrations docs pages. So there was in fact a recent change around the time it broke for you. But I’m unable to reproduce this on any of my browsers (Chrome, Firefox, mobile Safari etc).
I know Algolia was also used prior to the recent enhancement and it never caused any issues with pi-hole (i.e. I was able to access the search function).
Nevertheless, given the fact I can’t use the search function from any machine on my network, it stands to reason that pi-hole, being the common factor, must be the culprit (despite the lack of any logged reports of blocking).
I temporarily disabled pi-hole and I was immediately able to access the search function. OK, so it appears to be the culprit after all. I re-enabled pi-hole and expected to lose access to the search function. However, to my surprise, I didn’t; the search function continued to work. I closed/re-opened the browser, flushed its cache, etc and was still able to use the search function.
It’s unclear to me why disabling/enabling pi-hole cleared up the error, but it did. Maybe the action cleared/refreshed a cache; beats me but it works now.
Thank you both for your assistance. I’ll close out the Issue I posted in the GitHub repo.
NOTE
I can only assign a Solution to one of the posts that assisted me. I’ll grant it to cogneato’s post for being the first to correctly suggest the problem may be due to ad-blocking.
