I have 4 Wyze plugs that stopped working in HA after I installed the 2025.6.1 core update. The plugs themselves work through the Wyze app but not through HA. The settings for the devices say the Wyze Home Assistant Integration failed to set up.
Further to above, after finally getting a chance to examine the problem, it looks like the HACS integration is broken. The integrations panel also says that HACS failed to set up. It advises me to check the logs but finding things in the logs seems to be a black art. After June 13, 9:30 PM, I seem to have nothing regarding any of the Wyze plugs. HA is just running and processing events as they occur without actually doing anything.
I’ve had this happen with pretty much every HACS integration on this update.
Yesterday I reinstalled HACS and set up a new API key for Wyze. Things seem to back to normal.
Was gonna reply yesterday but forgot. Basically every similar issue on the HACS github was resolved by updating to the 2.0 (or greater) version of HACS
Can you point me to the complete instructions for integrating WYZE with HA? New to the platform. Using HA to finally get all of the cloud devices not supported by Hubitat to work in my house.
Many thanks.
Did you ever find out? Also new to HA and wanting to integrate my Wyze devices ![]()
