Does an Odroid N2+ support ffmpg and hardware accel in Frigate? I’ve had to comment out all efforts at making this work in frigate.yaml. My understanding is that there is hardware acceleration, but can’t get it to work in Frigate.
mqtt:
host: 192.168.1.103
client_id: frigate
user: harry1
password: Carrie_Feuer0SYN
go2rtc:
streams:
reolink:
- http://192.168.1.105/flv?port=1935&app=bcs&stream=channel0_main.bcs&user=admin&password=#####
- "ffmpeg:reolink#audio=opus"
reolink_sub:
- http://192.168.1.105/flv?port=1935&app=bcs&stream=channel0_ext.bcs&user=admin&password=#####
cameras:
office:
enabled: true
ffmpeg:
# hwaccel_args:
# - -hwaccel
# - vaapi
# - -hwaccel_device
# - /dev/dri/renderD128
# - -hwaccel_output_format
# - yuv420p
# input_args:
# - -avoid_negative_ts
# - -make_zero
# - -fflags
# - +genpts+discardcorrupt
# - -fflags
# - nobuffer
# - -fflags
# - low_delay
# - -strict
# - experimental
# - -probesize
# - 1000M
# - -rw_timeout
# - "5000000"
# - -use_wallclock_as_timestamps
# - "1"
inputs:
- path: rtsp://127.0.0.1:8554/reolink?video=copy&audio=aac
input_args: preset-rtsp-restream
roles:
- record
- path: rtsp://127.0.0.1:8554/reolink_sub?video=copy
roles:
- detect
detect:
width: 640
height: 480
fps: 5
birdseye:
enabled: true
record:
enabled: true
retain:
days: 1
events:
retain:
default: 2
mode: all
objects:
person: 2
snapshots:
enabled: true
timestamp: true
retain:
default: 5
objects:
person: 5
