I’ve got a Tasmotized Sonoff 433MHz bridge and it’s able to pickup the temp sensor 06002m from Accurite. It’s in hex, but from what I’ve read it’s a pretty involved thing to convert. I keep getting around the same temperature (D10FFE). Is there a ready made conversion for this? It can come in over MQTT
I think it’s not just straight hex. You have to shift binary digits here, and XOR these other digits there, etc. It’s convoluted.
I think you can use this to convert to a decimal:
{{ states(sensor.your-sensor) | int(base=16) }}
But i think only some of the string is relevant. Try this (then check units):
value_template: >
{% set hex_val = states(sensor.your-sensor)[-3:-1] | int(base=16) %}
{{ ((float(hex_val/10) * 1.8) + 32) | round(1, default = 0) }}
If all else fails, grab the rtl_433 source from GitHub and see how they decode the various AcuRite packets…
If you have some info on how its done, tell us so someone can convert it to a template.
