I have tried erverything in my power to make this image: Raspberry Pi 3 Model B and B+ 32-bit install on my pi. But it really does not work. I have tried several different sd cards, different power supplies, cables, network connection methods, different versions of BalenaEtcher… no dice it just WONT install. exactly nothing happens when I boot up the pi… this have frustrated me a whole lot the last couple of days, and for that reason I decided to install HS in side a docker container, buuuut found out that it is not a supervised version so I can’t install the addons that I need… or at least not easily. I then tried installing the Home Assistant Core this installation method also worked like a charm, buuuut this also didn’t ship with the addons store that I need.
About a year ago I flashed a Home Assistant OS image onto an sdcard and it did in fact install after I powered up the pi. The current image on the download page has to be a newer one with some changes done to it that just doesn’t work for my setup (pi version - whatever…)
I would really like to find older version of the installation image because I am absolutely sure that if i just get an older one I will be able to install Home Assistant OS again like I did last year.
Thanks in advance!
For the record, I have also tried the 64bit image, exact same result, nothing happens, no network connectivity, it never even preforms a handshake with my router over ethernet. nothing written to any of the files on the sdcard, nothing on the screen when hdmi connected - nothing.
EDIT: since many of you ask for the steps I followed…
1: downloaded: Raspberry Pi 3 Model B and B+ 32-bit
2: downloaded: https://www.balena.io/etcher/
3: flashed the image onto a Class A1 32GB micro sdcard
4: insert sdcard in rpi b3+
5: insert ethernet cable in router + pi
6: turn on the pi
7: waited up to 2 hours - pi never shows up when scanning with https://www.advanced-ip-scanner.com/
One thing that is worth to mention, is that as soon as i plug the power in the pi the red LED goes solid, the green blinks two times, and then never blinks again. This ONLY happens when sdcard with the lates hassOS image flashed is inserted, with all other images, the green LED is more active and most important of all, the etherned LED as well.
I would like to branch my steps… because as described, I have done a lot of different things to try and make it work. I have used 3 different sd cards, one class A2 16GB and another class A1 16GB. I have verified all my sdcards with h2testw to be fully functioning and be fast (10MBps write 20MBps read)
I have tried different power supplies and usb cabels. I have tried different port on my router, and different ethernet cabels, I have tried the version of BalenaEtcher I had already installed, and I have also flashed using the latest. I have also tried the wifi connection method by using a USB stick formatted FAT32 with only one partition called CONFIG network/my-network/my-network with the wifi configuration. For this step I followed this video: https://www.youtube.com/watch?v=xNK3IDxSPHo&t=453s&ab_channel=TechTech%26MoreTech time: 3:00 - 5:20
When I say I have done everything in my power I really mean it. Yes I have followed that exact procedure like 8 times swapping out sd cards, power supplies, ethernet cables, usb stick with wifi settings etc etc. waiting up to hours some times I have left my house to comeback later still no dice. It never even blink once on the ethernet activity indication led, not on the pi and not on the router.
