I get the following error - is there a fix for this?
Error setting up platform bluetooth_tracker
File "/usr/src/app/homeassistant/components/device_tracker/__init__.py", line 183, in async_setup_platform
disc_info)
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/src/app/homeassistant/components/device_tracker/bluetooth_tracker.py", line 72, in setup_scanner
for dev in discover_devices():
File "/usr/src/app/homeassistant/components/device_tracker/bluetooth_tracker.py", line 50, in discover_devices
lookup_class=False)
File "/config/deps/lib/python3.6/site-packages/bluetooth/bluez.py", line 26, in discover_devices
device_id = _bt.hci_get_route()
OSError: [Errno 97] Address family not supported by protocol
Error setting up platform legacy
File "/usr/src/homeassistant/homeassistant/components/device_tracker/setup.py", line 76, in async_setup_legacy
tracker.see, discovery_info)
File "/usr/src/homeassistant/homeassistant/components/bluetooth_tracker/device_tracker.py", line 82, in setup_scanner
File "/usr/src/homeassistant/homeassistant/components/bluetooth_tracker/device_tracker.py", line 57, in discover_devices
lookup_class=False, device_id=device_id)
File "/usr/local/lib/python3.7/site-packages/bluetooth/bluez.py", line 26, in discover_devices
