I have a HA installation in kubernetes that uses a mariadb database, when I run a backup in HA does that include the database or do I need to back that up separately and in the case of restore first restore the db and then the HA backup ?
Depends on how you have that setup. What version of HA are you running? If it is HA-OS, what I assume, than the database is included in the backup. Either being it the default SQLi file or the complete Add-on MariaDB.
But to be sure, check it for yourself:
- do a full backup of HA
- download the archive to your computer (.tar)
- open the archive with ie. 7-Zip and take a look into it
- you’ll see all the Add-ons that have been backed up, in case of MariaDB it should be
core_mariadb.tar.gz
Thanks,
I am running 2023.7 core in a (Kubernetes) container and the database runs on a separate Mariadb container. When I open the tar file, there isn’t anything there that resembles a database backup, so I assume I need a separate backup of the maridb
Yep, in that case you need to take care of it by yourself. The Add-on will only be safed, if it is installed as Add-on in HA.
To be totally clear, there are no kubernetes installation of HA:
- That are supported
- That could support addons
But someone running HA in K8S definitely doesn’t care about addons
Thanks, I am aware, its just the way I chose to run my containers
If you one day have too much time on your hands, you could share some more infos about your setup, might be interesting, not only for me.
