Can anyone tell me if I can use hacs with hassio? Because I cant seem to find/get the hacs integration from the list.
I did that already, i ran this command and it supposedly worked:
and then I restarted hassio, cleared the browser cache con my mac…was i supposed to clear the cache on the raspberry pi somehow? How do I do that?
Because hacs doesnt show up in the Integrations list.
Here?
If it doesn’t show up there, the last time I fielded a similar question the user had some garbage in /config/custom_components that was preventing HA from loading anything in there. Review your logs.
ok here is a screenshot of whats in my config/custom_components/ folder:
Thats everything I downloaded from the github:
https://github.com/hacs/integration/tree/main/custom_components/hacs
looks like you installed it in the wrong diectory. Do NOT change to cusom_components before running the script. The instructions are:
- Connect to the SSH add-on
- Run the HACS install script
All of that should be in a hacs
folder in /config/custom_components
, rather than directly in /config/custom_components
ok so how do i fix it now?
From /config/custom_components
mkdir hacs
mv * hacs
Then restart HA
Frankly I would delete the whole hacs directory and start again, following the instructions this time.
ok i removed the entire directory and went into the ssh addon and ran the script:
I restarted the raspberry pi and i still cant get hacs listed in the integrations. There is nothing else inside the custom_components folder except the hacs folder.
Have you followed this guide?
ok i had forgotten to do the cache thing this time around, so instead of clearing it i opened up an incognito window and it worked, i added hacs and apparently it has changed, because it no longer asks you for a token, instead it asks you to connect to your github account and i guess thats how its done now.
I will continue with sonoff lan now. thanks so much
