Does HLW8012 and change_mode_every set to never work?
Could someone check whether the HLW8012 device works with the change_mode_every:never setting? I’m trying to set it up to measure current only and if I use the never setting it don’t produce any values. If I set it to a very large number it works OK
    update_interval: 3s
    initial_mode: CURRENT
    change_mode_every: never    # seems to generate no values
but this works:
    update_interval: 3s
    change_mode_every: 4294967295    # about 408 years
I will put in an issue, but wanted another set of eyes on it to make sure it’s not something specific to my setup.
Thanks!
I encountered the same thing on an EMS01. I like your workaround, just as good of a solution.
