Does Home Assistant Support cheep LED Bulb
I found a couple of these on eBay, Just wondering if HA support it or not.
Some example:
https://www.ebay.com/itm/WiFi-IR-Remote-Control-Smart-LED-Bulb-E27-RGB-Light-For-echo-Alexa-Google-Home/253388217293?hash=item3aff1d5bcd:m:md1x0r3rAM2qSoJa86g4PFw
https://www.ebay.com/itm/Magic-Home-E27-7W-RGBW-Wireless-WiFi-Timing-Smart-LED-Lighting-Bulb-for-Smart-Ph/162098824338?hash=item25bdd7c492:g:QOMAAOSw9eVXWaMa
I am not sure about those bulbs. But apparently there is an ESP8266 based bulb that can be flashed with custom firmware to be MQTT aware and therefore compatible with HA.
Looks like the bulbs are about $15 on eBay. I may have to try this out myself :slight_smile:
Well, I’m not that good at solder sooo… just looking for my original question’s answer (:wink: It is really simple if it’s compatible
It is really simple. Those bulbs are not specifically compatible.
If they are in that list, they are compatible. If they are not, they aren’t. I don’t see them in the list.
Well I’m looking for a light that work with home assistant that doesn’t need to be hardware modded (Software mod OTA is fine I’m used to command line) for around 15$ price point,Any Suggestion?,Thank
Hue White bulb can be had for under $15 (hub still needed)
Tradfi (Ikea) bulb are in the $15 range I think
As for anything else, If bulb is MQTT aware or http accessible then HA can support it. everything else will require hardware mod.
I do have a hue bridge controlling 4 colored light and 2 light strip but The Hue white ambient are 45$ on my countries because of import charges
Look for LimitlessLED. You’ll need an ibox2 as well.
