I measure temperature and then calculate EC from that. If I apply a moving filter average to the temperature sensor and use id(sensorname).state in a lambda function to calculate temperature compensated voltage, willthe voltage be calculated using the result of the filtered sensor reading or the raw value?
I’m trying to smoothe out spiky readings and hope that the temperature compensated value is based on the filtered temperature value. I hope the wording makes sense.
Here is the code:
Thank you!
# Temperature In °C
- platform: dallas
name: "Water Temperature"
address: 0xa709225351725c28
accuracy_decimals: 3
filters:
- sliding_window_moving_average:
window_size: 15
send_every: 1
send_first_at: 1
# Temperature Compensated Voltage
name: "TDS 01 TCV"
unit_of_measurement: 'v'
lambda: 'return ((id(tds01_raw).state) / (1 + (0.02 * ((id(waterds18).state) - 25.0))));'
update_interval: never
internal: true
edit:
Thanks! That makes sense. I was unable to google it or find it in the docs.
