Does not recognize LEGRAND GATEWAY
Hello! I’m new to the community, and after the first installation of HA on a Raspberry Pi, I had a problem and my SD card crashed.
When reinstalling Home Assistant, my LEGRAND Valena Next ecosystem isn’t automatically detected, and I have to integrate it through NETATMO, which depends on the internet to work. I’ve also experienced several issues with this integration that I didn’t have before (for example, the blinds’ opening percentage doesn’t work properly).
After the first installation, HA detected it as a HOME KIT gateway (I don’t have a Home Kit at home), and it worked perfectly, with many more entities than through Netatmo…
How can I get it to detect it automatically again? I’ve tried going back to a previous version, and that doesn’t work either…
Thank you so much! HA is amazing!
Fixed it, resetting the gateway and heating relay has reappeared for me to add to HA. Apparently, HOMEKIT systems are linked “forever” unless you reset the system or can unlink it from the HOMEKIT app. In this case, since it was integrated into HAOS in a previous installation, it wasn’t possible to unlink it… In case it helps anyone!
