Does not send any data
Hello everyone,
I recently installed Home Assistant OS on a Raspberry Pi 3B+ using RP Imager. Everything was running smoothly yesterday, and I could access Home Assistant through both the IP address and DuckDNS domain.
However, this morning I received a message indicating that my IP address didn’t send any data. When attempting to access it through the URL, I encountered the same issue.
when i try to acess another servers installed by homeassistant every thing works smoothly such as inginx 192.168.1.134:81 it works
If you attach a monitor and a keyboard, what do you see ?
i do not have a monitor and a key board
now i tried to write https://my domain name :8123 it worked
i do not understand why ?
Did you try http://my.domain.name :8123 before ? Once you enable https:// the http:// does not work anymore.
YES , you are right i realised this right now thanks.
