Does switch toggle (not button) exist in frontend?
Home Assistant has these beautiful and intuitive switch toggles for switch entities:
Example of a switch toggle
This is shown if one goes to the device and clicks the entity in question. Confusingly, I’m unable to find this switch amongst the frontend dashboard cards. Does it not exist as a frontend card in Home Assistant, despite it being implemented in other parts of Home Assistant??
I find the “Button” card, which is functionally similar, but I think it’s much less elegant and does not indicate as clearly the type of the entity.
If the switch toggle exists, I must be blind because I’ve been scrolling through the list of cards a bunch of times now…
Those switch toggles are usually in the “more info” for a dashboard card. You can make that a card in it’s own right with the more-info-card from HACS.
