I gave up trying to have the HACs Tapo Camera Control integration working. Tapo seems to have no interest in having 3rd party apps access it. So I uninstalled the HACs integration.
Then I updated the Tapo C210 to the newest firmware which was held back in order for the HACs integration to work. Now I’m trying to add the camera.
The Tapo app works fine, I can see the camera. I’m having trouble adding the camera through the ONVIF integration. I enter the proper IP, the proper username and password, and the ONLY port that the integration will support is 2020. So using 2020, it saves the configuration and adds the camera.
I re-started Home Assistant. Everything looks fine on the Integration page, but when I click on the camera device, or either of the 2 entities (different streams), it shows the camera as idle. Double clicking on the stream, the screen is blank.
Any ideas?
