I have three Doit ESP32 Devkit V1’s, purchased a few years back. I originally programmed them as stand alone items with arduino studio for some basic projects and I am now trying to add them to my set of ESP32s in my Home Assistant. In HA I currently have around 6 ESP D1 Minis for temperature, humidity and electricity monitoring around the house, so all good with them. I am able to use the ESP home web page to prepare the Devkit V1 devices for initial use, but when I try to edit then install the devices from within ESP Home in HA I am getting compile failures.
Example sample config yaml and compile logs are shown below, if someone has a working Doit ESP32 Devkit V1 config then do please share how I can get this working. Its just a shame to have these 3 devkits sitting around not being used.
Note that I have obviously tried many different board types etc etc in the config yaml but I just cant get it to work so if you suggest “try this… it may work” likelyhood is that I have and it doesn’t but I am grateful for any help. If anyone has a concrete working solution then all the better…
BTW, I’m frquently updating HA, ESP Home and all devices to the latest versions.
Example config:
esphome:
friendly_name: ESPHome Web ee23f8
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "yyyyy"
ota:
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esphome-Web-Ee23F8"
password: "zzzz"
captive_portal:
Compile Output:
INFO ESPHome 2023.12.8
INFO Reading configuration /config/esphome/esphome-web-ee23f8.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing esphome-web-ee23f8 (board: esp32dev; framework: arduino; platform: platformio/[email protected])
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
- toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
warning: Calling missing SConscript without error is deprecated.
Transition by adding must_exist=False to SConscript calls.
Missing SConscript '/data/cache/platformio/packages/framework-arduinoespressif32/tools/platformio-build.py'
File "/data/cache/platformio/platforms/espressif32/builder/frameworks/arduino.py", line 41, in <module>
Library Manager: Installing FS
Warning! Could not find the package with 'FS' requirements for your system 'linux_x86_64'
Library Manager: Installing Update
Warning! Could not find the package with 'Update' requirements for your system 'linux_x86_64'
Library Manager: Installing ESPmDNS
Warning! Could not find the package with 'ESPmDNS' requirements for your system 'linux_x86_64'
Dependency Graph
|-- AsyncTCP-esphome @ 2.0.1
|-- WiFi @ 1.2.7
|-- ESPAsyncWebServer-esphome @ 3.1.0
|-- DNSServer @ 1.1.0
|-- noise-c @ 0.1.4
Compiling .pioenvs/esphome-web-ee23f8/src/esphome/components/api/api_connection.cpp.o
Compiling .pioenvs/esphome-web-ee23f8/src/esphome/components/api/api_frame_helper.cpp.o
In file included from src/esphome/components/socket/socket.h:6,
from src/esphome/components/api/api_frame_helper.h:14,
from src/esphome/components/api/api_connection.h:3,
from src/esphome/components/api/api_connection.cpp:1:
src/esphome/components/socket/headers.h:156:10: fatal error: sys/ioctl.h: No such file or directory
#include <sys/ioctl.h>
from src/esphome/components/api/api_frame_helper.cpp:1:
compilation terminated.
*** [.pioenvs/esphome-web-ee23f8/src/esphome/components/api/api_frame_helper.cpp.o] Error 1
*** [.pioenvs/esphome-web-ee23f8/src/esphome/components/api/api_connection.cpp.o] Error 1
========================= [FAILED] Took 20.67 seconds =========================
