I’ve this error every 5 seconds: WARNING (MainThread) [homeassistant.components.dnsip.sensor] Exception while resolving host: (4, 'Domain name not found')
I’ve no ideas…
My configuration is Hassio with reverse proxy. No DynDns or similar. No custom dnsip sensor configured.
No I don’t have the certificate integration installed, but how does it deal with my problem?
I just installed this plugin and now I’ve a new sensor that store the expiring date of my certificate…and so?
The warning is always there, every 5 seconds.
Is it possible that something about old broken installation of duckdns create dusty orphan code somewhere?
or
How can I check all my configuration searching about ‘dnsip’? In my opinion the warning come from there. (all yaml file are dnsip free )
I found the bad config file in sub sub sub folder.
I’m searching dnsip string in all files recursively by terminal grep and i found it in a old cut and paste config.
Below the simple search command for future googlers…
