I have a pair of these dome sensors and I’ve got them added to my HA without issue, but they are not updating when the i open doors/windows.
I know from a previous issue with some water sensors i had to change the “Report type to send” from 255 to 17. However on these devices I can’t find that option anywhere. Using both the HA zwave config or OZWCP. Its not listed in the configuration.
Then there is another issue, remove the sensors and re-add them, after you remove them, delete the entity ID’s from the entity file, after you re-add them, keep the sensor and magnet separated for a few minutes then restart HA.
I add them, The entities show up. Everything looks good. But when I separate the magnets, HA or the Zwave network dont show any changes. I have the OZW.log running so I can watch for changes, but it doesn’t show.
I’ve tried restarting with the magnet separate at first and together. Each time I remove and re-add them I remove it from the entity registry also.
I’ve tried checking in OZWCP to see if it updates and even there it does not see the change.
Im 4 feet away from my Zstick, no obstructions.
These are brand new sensors with new batteries (double checked they were full). Two identical sensors, same issue.
The issue is the entities created are not updating on state changes. ie, when the physical magnets are seperated, no notification is being sent to the zwave network.
When I added mine, I left the cover off for about 5min, this forces the sensor to stay awake and the system is able to get all the parameters of the sensor.
